Previous in Forum: 3Phase to Single Phase Conversion   Next in Forum: AC Generator AVR
Electrical Energy Report
04/16/2010 3:40 AM
We have been assigned Electrical Energy Audit of Hatchery unit.Will request friends to guide me in preparing the report.we have collected all the data now have to compile the report, so needs some tips to write the report. Thanks
User-tagged by 1 user
Re: Electrical Energy Report
04/16/2010 8:59 AM
  1. Report Writing; An Introduction Oct 21, 2009 ... How to write better reports, easier, so that they will be read and have some effect. Introduction to the training module on report writing.
    www.scn.org/cmp/modules/rep-int.htm
  2. [PDF] REPORT WRITING File Format: PDF/Adobe Acrobat
    Two common mistakes in report writing are to overestimate a reader's knowledge-and blind them with science, or to underestimate it - and bore them to tears. ...
    lorien.ncl.ac.uk/tskills/reports/repwrite.pdf
  3. Sample Report What is most important about report writing is that you have carefully considered the rhetorical situation. When you prepare your report, be sure to analyze ...
    www.ic.arizona.edu
  4. Image results for report writing
  5. Report Writing A key ingredient for writing a good laboratory report is taking good lab notes and writing down observations. (see Preparing for Lab) ...
    www.uic.edu/~magyar/Lab.../Report_Writing/report_writing.html
  6. Report Writing - How to Format a Business ReportNov 15, 2005 ... Report writing is a time consuming business so it is a great shame if, having devoted all that time to writing your report, the quality is ...
    ezinearticles.com/? Report-Writing---How-to...Report.
  7. Scientific Report Writing
Good Answers: 49
04/17/2010 12:39 AM
I assume that the reason for the audit is to identify how much energy and related costs are associated with the various processes at the site and then to try to identify ways to cut those costs without compromising production or quality.
I have found that the most effective method of presenting this data is to take a two-fold approach.
First- determine the level of monthly energy usage that is dependent on weather conditions and then determine the level of usage that is constant and does not change regardless of weather conditions. Once you know those numbers, you know how much energy usage and costs can be lowered with improving thermal efficiency. You also know how much usage and costs are constant. This way, you can look carefully at those costs and determine WHERE and WHY the energy is being used so that you can look for opportunities to reduce that usage.
Second- (and this goes right along with the first action) Develop a Pareto Chart, like is used in quality control, where you present the energy users in decending order in a bar chart format so that it is totally obvious which machines or sub-systems are using the highest amount of energy and thus costing the most. This allows you to focus your solutions on the devices that have the highest opportunity for cost reduction.
Your presentation of solutions should be first- items that are risks to health or safety, second- items that are risks to reliability or quality and finally, items that save energy and money, presented from the most economically attractive and highest payback down to the least attractive.
By presenting your information in this manner, virtually ALL readers will be able to understand your data and how it fits into the big picture as well as what needs to be done to make the world get better.
Hope that this helps.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Register to Reply 2 comments
