Previous in Forum: UK Libel Law Reform - BCA drop their case against Simon   Next in Forum: Trompe Efficiency
18 comments
Floating Homes
04/16/2010 12:27 PM
Has anyone thought about building houses and businesses on barges and sinking them into the ground? The idea is to allow the house/business to float in areas prone to flooding like along rivers and coastlines. The barge would be set flush into the ground and have guide posts at the corners to keep the barge on station while afloat. Once the flood waters have receded, the barge with the house/business would settle back down to ground. Connections for water, electricity, gas and sewer would have to be flexible. The cost of such a structure, could be less than the cost to rebuild, replace and/or repair flood damage. Some areas of the country see flooding almost on an annual basis. Flood insurance, as you know can be very expensive.
Mr.Ron from South Ms.
Good Answers: 114
Re: Floating homes
04/16/2010 3:20 PM
I have a vision of people buying up the narrow boats and putting then together like doublewides and triplewides.
Good Answers: 183
Re: Floating homes
04/16/2010 2:53 PM
Already developed and in (small still) series construction in the Netherlands.
Good Answers: 266
Re: Floating homes
04/16/2010 3:00 PM
Their called house boats. I don't think everyone would be able to afford a home built like one on the chance there is a flood. Why do you think many of these people bought homes in a probable flood zone to begin with.
Good Answers: 183
Re: Floating homes
04/16/2010 3:33 PM
Due to the situation in the Netherlands they are OBLIGED to think about solutions in the case of see level growth. It is NOT a choice it is an imposed solution.
Good Answers: 60
Re: Floating homes
04/16/2010 3:30 PM
as well as cost another problem is if there is fast flowing water you would need some really substantial anchors to stop it moving.
it would be cheaper to mount the properties on stilts. above the last known high water line,
Re: Floating homes
04/16/2010 8:34 PM
In many parts of the U.S. people live in houseboats which are nothing more than a steel or concrete barge with a house built on it. It is permanently moored and is pretty much safe from flooding. Some of these houseboats cost in the millions of dollars and rival any land based house. It's stil a good idea. Just wish I had thought of it before. If the waters rise over the earth, we will be forced to a houseboat solution or move to higher ground.
Good Answers: 60
Re: Floating homes
04/16/2010 8:48 PM
oh i dont deny its a good idea, but as some one else has said most of the propertys tha get damaged are accomadation for poor people and to fit floatation devices may be expensive.
My parents had a holiday home at the side of a reiver here in the uk that got flooded a lot.
I suggested floatation then, but again most people think of the cost,
when i said floods i meant the sort that washed normal buildings away recently in use.
if it wash away fixed structures then boats would be easier
http://www.google.co.uk/imgres?imgurl=http://img.dailymail.co.uk/i/pix/2006/11/floods_468x305.jpg&imgrefurl=http://www.dailymail.co.uk/news/article-415276/Homes-swept-away-flash-floods-hit-US.html&h=305&w=468&sz=52&tbnid=r19hKspzFwcSAM:&tbnh=83&tbnw=128&prev=/images%3Fq%3Dfloods%2Bin%2Bus&usg=__WHReCRbncGEncxWXTQZ6Br0n4Sw=&ei=QATJS-PQKof40wScuLXbDA&sa=X&oi=image_result&resnum=6&ct=image&ved=0CBUQ9QEwBQ
Re: Floating homes
04/17/2010 1:03 AM
Don't worry! God said He would never destroy the world by flood again!
Re: Floating Homes
04/17/2010 1:06 AM
Dear Ronseto,
Houseboats abound worldwide. A permanently anchored floating house is not :impossible, provided the cost can be met. ( I was once asked to be involved in the anchoring design of a : Floating Hotel ! )
There are a number of ways:
1.A steel or cement coffer dam cube i.e with a waterproof slab base. Within same a variety of systems can be envisaged :
a.Jacking up the house on stilts.(The stilts themselves would need a number of steel pipe housing to protect their instant use . i.e. these water tight steel pipes would, after earth drilling , protrude undeground giving enough lenght for the stilts to be housed when not in use .The steel pipe or housing would garantee these stilts a solid footing when activated.
This system would duplicate what is known as a " jack- up " rig or drilling platform, which has rack and pinion methods of elevating the load. Which in this case would be the house.
2.Air bags, or in diving parlance: "parachutes". In diving these are used to lift loads by capturing/retaining air that is pumped into a parachute like air bags. As in the above application there has to be an adequate , yet again : cofferdam . Within which the "air bag "is permanently stored and ready for use. The air bag need not have a bottom to it as its side curtains would retain the air ( Adequate allowance for the air bag sides being folded - when not in use- would need to be provided for in the perimeter of the underground coffer dam.This by way of ( a lower ) excavated concrete channel .
Of the two above suggestion the stilts have the least exposure to forces of : flowing water. In floods you are never quite sure of what floating debris can come at you: an uprooted tree or even another house !
There are numerous adaptations.However and , at all times , you need to know what will be the parameters of : the soil , the approximate( more than 150 years flood history ) level and the likely speed of the flood current so as to calculate the integrity of the design. The next important items being:
a) that of anchoring the floated structure. As well :
b) how to minimize debris, soils etc being left in the cofferdam by the flow and having same cleaned out after the flood subsides .
In short unless you are bound , as the Dutch are , to your plot of the planet, take a deep breath , measure the size of your pocket, or find higher ground.
Labor Omnia Vincit.
Good Answers: 145
Re: Floating Homes
04/17/2010 1:36 AM
I would ask you to consider what the cost of maintenance of a typical house built on a raft/barge. At some stage it would have to be lifted up out of the ground and the "hull" inspected to ensure its still sound or sea (flood?) worthy.
Not impossible but at an interval of every five years I can see a new growth industry..
The logistics of connecting the services in a suburban environment, taking into consideration that the water may rise several meters for a period of days. Expensive.
Not to mention what if just one house slipped its moorings during aflood, and crashed into some more houses, with the force of flood waters combined with the flotsam and debris that accompanies it. Could lead to some serious carnage. A typical house, on its attendant barge would weigh around 25-30 tonnes and it can't manoeuvre on its own.
Considering the way most (not all) boat owners treat (neglect) their pleasure boats, I wouldn't think this a candle worth lighting.
As much as i would love to live aboard a houseboat on a lake or yacht on the harbour, not much appeal to it in suburbia..
Good Answers: 213
Re: Floating Homes
04/17/2010 1:58 AM
You have essentially described a typical marina. You may also want to have a look at Hong Kong, which has a whole section of town full of people that have never set foot on dry land...
Re: Floating Homes
04/18/2010 11:13 PM
"Hoklo and Tanka are 'boat people' who live in junks floating on the waters off Aberdeen, Yau Ma Tei, and other typhoon shelters. Although most of them have come ashore to dwell, there are still the older generations who continue to carry on their traditional way of life on their narrow junks".
Not many if any these days, quite sad really, but a lot less sh*t in the water.
Re: Floating Homes
04/17/2010 8:40 AM
I live in Cedar Rapids, Iowa, where we have--or had, I should say--a marina full of houseboats. When the great flood of 2008 happened, 60 of those houseboats were ripped from their moorings, carried downstream, and destroyed.
Based on that experience, I suggest that you build a houseboat for the joy of living on the water, but don't expect it to survive a major flood.
Life is like a sewer. What you get out of it depends on what you put into it.--Tom Lehrer
Good Answers: 114
Re: Floating Homes
04/17/2010 8:44 AM
You might be interested in this. MOMA put some teams of architects to work on solutions to a rising sea level.
Slideshow
Re: Floating Homes
04/17/2010 3:21 PM
In a flood prone area I think it would make more sense to just build a 8 -10 foot high concrete basement underneath the house. Concrete steps or ramps would be added to get up to the house. If experts think water will ever get higher than that, then you shouldn't be allowed to build a conventional house in that area anyway, and if you do, you do it knowing that you are not covered by any Insurance or Government help should a flood take place. Or simply, people are not allowed to build in flood prone area's in the first place,,,,,,,,,,,,,, period.
Good Answers: 25
Re: Floating Homes
04/19/2010 11:11 AM
Assuming that your barge was sunk into the ground and assuming that your barge was water tight and stayed in position and assuming that the water went back down, what do you suppose the chances are that there would be a clean spot for the barge to settle back into? Every flood I have seen leaves a lot of crap behind. A dead tree wedged against the barge would likely cause your morning hard boiled egg to roll off the plate after the water receded!
Goodness has nothing to do with it.
Re: Floating Homes
04/19/2010 2:42 PM
Great Point....
Register to Reply 18 comments
Anonymous Poster (3); beriberi (1); cwarner7_11 (1); nick name (2); ozzb (1); passingtongreen (2); peterg7lyq (3); Rescue (2); ronseto (1); Slow Old Poop (1); Tobugrynbak (1)
