Previous in Forum: Floating Homes   Next in Forum: infringement Attorney
Trompe Efficiency
04/16/2010 12:29 PM
I have been looking at tromp design and wondered were the "extra energy" extracted from the compressed bubbles which are harvested from such a device is calculated.
If a flow of water falls from level A to level B the potential energy can be easily calculated.
Where air is added to the water at point A and extracted near point B.Work has been performed on the compressing of the air, with ouit any apparent expenditure on the flow of water. Would there be a measurable "slow down " in the velocity of the water when bubbles are added? and if so what is the compressor efficiency?
GF
THE PROOF OF THE PUDDING, IS IN THE EATING.
Pathfinder Tags: trompe compressor
Good Answers: 60
Re: TROMPE EFFICIENCY
04/16/2010 2:44 PM
Good Answers: 60
04/16/2010 3:11 PM
and
http://www.viswiki.com/en/Trompe
a bit of light reading
http://espace.library.uq.edu.au/eserv/UQ:9433/coe02_1.pdf
look at this design its basicly the same concept except it has moving parts
http://outlands.tripod.com/farm/rampump.htm
Good Answers: 60
04/16/2010 3:15 PM
Re: Trompe Efficiency
04/17/2010 3:51 PM
It is easy to calculate the energy component used to compress the air.(this is only a couple of percent in my case) I have been looking at my pulser pump figures from the late 1980's and I do not remember how I calculated the efficiency of the tromp section! It was a really low head trompe (half meter head) so the compressed air production figures were only about 30%. Someone in England did research that suggested 60% efficiency for trompes or better if head was around 2 meters.
I think what I did was substitution. I was pumping air down to replace water at 3 meters deep so that is more or less the same as pumping the replaced water 3 meters higher. And it is easy to calculate the potential energy of that water, . mass by acceleration due to gravity by height. (I think you substract the mass of the air that is under pressure). It has been decades so I forget how I did it. People are convinced that you need a venturi in a trompe but acceleration as the water falls in the pipe is all you need to entrain air. If YOU were fluid and accelerated headfirst from a horisontal inletpipe to a vertical downpipe, you would stretch as your head accelarates faster than your feet. The stretching would leave room for air. Water does not expand to fill the space!
The effects on the flow of water from the work done by compressing the air are subtle. There is less turbulence in the exit water. (So it will not pick up silt and clay and sand as readily as water exiting from a normal waterfall). That is the main difference. The turbulence is gone. Turbulence is not a very visible thing so it does look much the same.
Register to Reply 4 comments
