Previous in Forum: Isolator   Next in Forum: Reverse Power
HV substation design and calculations manual
04/17/2010 6:53 AM
Hi all
can any one have good advice for this
thanks
Correct me if i am wrong i am learner
Re: HV substation design and calculations manual
04/17/2010 11:54 AM
If you don't already know how to do this job, I suggest that you don't try using a manual. I think that the guys who spent 10 or 15 yesrs learning this skill would agree. Thats good advice.
Good Answers: 244
04/17/2010 2:34 PM
These are some of the good documents that can help:
http://www.usda.gov/rus/electric/pubs/1724e300/1724e300.pdf
http://www.iso-ne.com/rules_proceds/isone_plan/pp9_appendix_b1.pdf
The first one is pretty big but informative.
- MS
04/18/2010 2:24 AM
Hi
All
thanks for the useful comments .One if dont know doesnt mean dont try to .I am working in MV/LV up to 13.8kV but i am trying to learn more now in HV/MV area .Of course it will take time but thousand mile journey start from single step :)
Thanks
04/18/2010 2:44 AM
Totally agree, every human being is not born with an electrical degree ,so start learning no matter what the odds are. Motivation and perseverance is two qualities needed to reach your goals in life.So soldier on .
Engineering Fields - Electrical Engineering - Hentoyk Philippines - Member - BRUTUS Saudi Arabia - Member - Brutus United Arab Emirates - Member - Brutus
04/18/2010 7:25 AM
Okey guys good luck to long distance tramission line journey, saddled up your horse. Learn while you ride.
If there is a will... there is a way... No pain / No gain.
08/03/2026 7:27 AM
A well-designed HV substation requires careful planning, accurate engineering calculations, and compliance with IEC/IEEE standards. Key aspects include load flow, short-circuit analysis, protection coordination, earthing design, equipment sizing, and SCADA integration. At VSS Power Engineering Services Ltd., we focus on delivering safe, reliable, and efficient substation engineering solutions for utility, industrial, and renewable energy projects.
04/18/2010 5:31 PM
Even if you are in an urban area (in Pakistan, I presume), Msamad's first suggestion looks like a treasure trove of good information. As you study this, please come back with questions you may have.
Register to Reply 7 comments
hentoyk (1); ikhanuk (1); msamad (1); RITESH KANDHAI (1); Tornado (1); VSS POWER (1); wareagle (1)
