Previous in Forum: Downgrading to Windows 7   Next in Forum: Laptop HDD
Tutorial CD file cannot run from PC
04/17/2010 9:07 PM
Hi, All
I had copy the tutorial CD to my Harddrive after copying complete. i run the tutorial CD from my Hardrive however a message pop up asking for the CD to load into my Cd drive. i there a way to by pass, cause the file is in my Harddrive.
Regrd's
Good Answers: 60
Re: Tutorial CD file cannot run from PC
04/18/2010 4:42 AM
enlish not a strong point then ?
Good Answers: 60
04/18/2010 4:43 AM
SHOULD READ english not a strong point then
Good Answers: 119
04/18/2010 1:05 PM
If the tutorial file path or links that point to the CD drive are located in a simple file (or files) you can edit, such as
*.ini *.inf *.bat *.htm *.html
you need to edit these files to point to c:\ instead of d:\
This is assuming you have one hdd partition and one CD drive. If the links are part of an executable file, like
*.exe
or you didn't understand the suggestions above, you should just run the tutorial from the CD.
