Previous in Forum: Hot Water Pump   Next in Forum: Why am I Quitting CR4?
Heat Exchanger Stanby
04/21/2010 2:20 AM
Does a heat exchanger need to have a stanby unit too.?
Re: heat exchanger stanby
04/21/2010 3:27 AM
It depends on how critical its process is.
Good Answers: 101
Re: Heat Exchanger Stanby
04/21/2010 11:28 AM
Yes, like any critical piece of equipment, you'll need one if your work processes are such that you cannot afford to have it taken offline even for maintenance.
04/22/2010 12:58 PM
NO!
04/23/2010 1:26 AM
@ Mr. Anirudha-
What would be base for not keeping a standby for Heat Exchanger ?
Register to Reply 4 comments
aaborkar (1); ANIRUDDHA_HARSHE (1); DVader1000 (1); Tornado (1)
