Previous in Forum: Energy Used Smelting and Rolling Steel   Next in Forum: Heat Exchanger Stanby
Hot Water Pump
04/20/2010 11:54 PM
Plz suuggest me Pump of 50 LPM for Water Temperature 80 Deg. Cent. with pressure 35 Bar.
Re: Hot Water Pump
04/21/2010 1:08 AM
I would search "boiler feedwater pumps" to find several types that might be suitable.
Good Answers: 137
Re: Hot Water Pump
04/21/2010 4:43 AM
That's a helluva pressure for a hot water pump. I assume that's the actual pressure, also need to know pressure rise to enable selection.
Grundfos have a good website where you can make selection, but I'm not sure they go as high as 35 bar.
Cheers...........Codey
Re: Hot Water Pump
04/22/2010 4:37 AM
Wanner Engineering Inc. do a H-25 Hydra-Cell pump that may be of interest. The maximum temperature is 121 deg C - Your should consult the factory for correct component selection for temperatures above 71 deg C. The discharge pressure is variable to 69 bar and the flow of the H-25 is up to 75.7 LPM. This pump is positive displacment so you will need to fit a PSV. The flow rate is directly proportional to the shaft rpm, so you can fix the flow rate by a fixed speed gearbox, variator or VSD.
Re: Hot Water Pump
04/24/2010 1:29 PM
Your Description of pump operation should have NET POSITIVE SUCTION HEAD, THEORITICALLY TO COMPENSATE FOR 80 Deg.Celsius + Frictional Head + Some safe margin of head.Then only the Pump will work.
Of course power required can be simply calculated.
DHAYANANDHAN.S,
INDIA.
Register to Reply 4 comments
Anonymous Poster (1); Codemaster (1); dhayanandhan (1); Tornado (1)
You might be interested in: Bar Code Software, Bar Code Cards
