Previous in Forum: High Pressure Transparent Tubing   Next in Forum: Saw Calculator
Moving a Polar Cutter
04/21/2010 5:58 PM
I have to move a small (28") Polar guillotine cutter(2900 lbs). I have seen larger units lifted using blocks of wood above and below forklift forks placed through the throat of the machine and lifted by the clamp but I think the movers somehow locked the clamp in position with a bolt? anyone know about this?
Thanks
Brad Green
Good Answers: 141
Re: Moving a Polar Cutter
04/21/2010 11:35 PM
Is the knife completely away? If yes, you can try it.
There might be a transportation pin hole. Check along the travel way of the guillotine. Be careful, if it is a mechanical one the knife can fall down partially or just enough to cut fingers.
If that knife still shows, don't take no forks, even with wood between. You could end up with a bended knife. Success
I should take a big pry bar and lift it a bit, put wood underneath at different spots, so that the forklift can take it at th bottom. Will be easier to put it on a truck (on wood) if needed. Take a forklift that can handle the weight.
Plenty of room here
Good Answers: 54
04/23/2010 1:43 AM
Is a Polar guillotine just a normal guillotine that's undergone a coordinate transform?
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 141
04/23/2010 1:56 AM
here are some - copy and paste
http://www.polarsales.co.uk/
Plenty of room here
Good Answers: 120
04/23/2010 5:58 AM
The maker would be glad to help you. Just ask
Per Ardua Ad Astra
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
04/23/2010 11:55 AM
When moving the smaller Polar cutters you can do so with the bed attached and pick it up using the clap as a lift point.
Here is how its done providing you have removed the anchor bolts and disconnected the power.
Put some cardboard between the clamp (Use the false clamp plate) and your forks at the widest point you can open them and still fit in the clamp opening.
Use a strap from the back of the bed to the headache rack after you have gotten the forks to meet up with the clamp. This is to control the tilt as the cutter will be heavy in the back.
After you have gotten everything set to lift slowly rais the forks until the base of the cutter just clears the floor.
Tighten the strap to equalize the weight and balance the load.
Slowly move the cutter to its new location.
Installation is reverse of the removal.
Level the cutter, bolt it down and hook up the power.
Thats about it.
If necessity is the mother of invention then is laziness the mother of necessity?
aurizon (1); double_j_b (1); dvmdsc (2); ffej (1)
