Previous in Forum: Pastics Manufacturing Textbook   Next in Forum: Moving a Polar Cutter
10 comments
High Pressure Transparent Tubing
04/21/2010 4:13 PM
Hi, I am trying to find clear tubing (US) of any kind with the following specs:
Color: Transparent
Inside Diameter: .300 to .450
Temperature Range: 0°F to 200°F
PSI Working Range: 0 - 400
Does anyone have any suggestions? I have looked through all of my resources.
Pathfinder Tags: high pressure clear tubing
Re: High Pressure Transparent Tubing
04/21/2010 4:40 PM
How about gauge glass tubing, as used for checking water levels in boilers? A steam valve and accessories supplier would be a good source.
04/21/2010 8:02 PM
Great suggestion. I ran across this after making this post. It appears to do everything I need it to do. But I have yet to find a supplier of adapter fittings or compression fittings to attach anything to this tubing.
The suppliers who sell the tubing do not carry fittings, and the suppliers who carry fittings do not know anything about pyrex or glass boiler tubing.
Any suggestions?
04/21/2010 8:12 PM
How about just getting some 'replacement' glass cocks:
http://www.nciweb.net/tubular.htm
You can probably get the glass through them as well.
04/21/2010 10:50 PM
The usual device for this is a "gauge glass valve." They are made in various materials and configurations, and incorporate packing glands (like a compression fitting) with suitable seals depending on the type of fluid and temperature. McMaster-Carr might be a source. I used to use Seattle Steam Supply when I lived there; many cities would have a similar entity.
04/21/2010 4:42 PM
Looks like it's going to be pretty hard to find. What are you going to use it for?
04/21/2010 8:04 PM
That, I cannot tell you atm. I can just say it is something you would want to see.
Good Answers: 141
04/21/2010 11:45 PM
drugs, alcohol or a big high pressure tea pipe
Plenty of room here
04/21/2010 5:01 PM
I've used clear PVC tubing. OK, pipe.
Pipe-Schedule 80
04/21/2010 7:59 PM
PVC clear sch 80 pipe has a degrade factor when temperatures increase above 73° F. At my required temperature range it specs to hold only about 100 PSI. Good suggestion tho.
06/30/2010 12:10 AM
You may want to check with a company called Bond Fluid Air, google that and if nothing else they will know who to send ya to.
What if...
Register to Reply 10 comments
Anonymous Poster (2); dvmdsc (1); lyn (1); Mikerho (1); plancette (2); Tornado (2); Whatif (1)
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
