Previous in Forum: Effect of Power factor improvement on gen-set petrol economy.   Next in Forum: DC Link Voltage in AC Drive Rise - Cement Mill Classifier Application
9 comments
motor power
04/23/2010 1:25 AM
you have been given a motor rating as 350W and it is running for 7200 hours.how do you calculate its power consumption?
Good Answers: 53
Re: motor power
04/23/2010 1:33 AM
Watts x hours = watt hours, good luck with your class.
Re: motor power
04/23/2010 4:43 AM
yes exactly the ACE has given correct anawer
Re: motor power
04/23/2010 5:53 AM
Its power consumption is up to 350W while it is running, depending upon the load applied to it.
Its energy consumption is that figure multiplied by the time it is running.
http://www.evsource.com/articles/mind_your_units.php
Good Answers: 53
Re: motor power
04/23/2010 10:15 AM
I think efficiency has to be factored in as 350 watt is rated power(O/P).
Re: motor power
04/23/2010 10:38 AM
Given Motor power 350watts
work done = 350 * 7200
=2520000/1000 (one unit = 1000watts for one hour)
=2520 units
Good Answers: 50
Re: motor power
04/23/2010 11:49 AM
You cannot calculate power consumption easily, it depends on what load it is running at. Your wording also implies confusion between power (rate of work in watts or kW) and energy consumed (watt-hours, or kWh normally, not joules). You can calculate approximately if you estimate the load value.
e.g.
If 100% load and 87.5% efficiency, then total consumption is (350/0.875)*7200/1000 = 2,800kWh. Rate of work is 350/0.875=400W or 0.4kW.
If 50% load and 84%, this is ((350/2)/0.84)*7200/1000 = 1,500kWh. 208W or 0.28kW.
Do you know the load and why do you ask? Your question is very incomplete and lacking in information to sensibly assist you - please add more details.
If you want to know the actual consumption, it's relatively easy to just measure it.
Something new every day!
Re: motor power
04/23/2010 12:59 PM
It's homework! Look at the structure of the question.
Good Answers: 50
Re: motor power
04/25/2010 3:23 PM
Sure you're right - thanks.
A bit of feedback would be well received sometimes, too, wouldn't it? Info into a black hole.........
cheers
Re: motor power
04/26/2010 2:03 AM
if you used your motor at its power rating (350W) so you have consumed 350 x 7200 = 2520000 Watt hours or 2.52 MWh
Ace Boeringa (1); Anonymous Poster (2); luv123 (1); lyn (1); MalcolmK (2); PWSlack (1); rakesh_semwal (1)
