Previous in Forum: baseload of gas turbine   Next in Forum: Steam Turbine Power Flactuating
11 comments
Submersible Pumps
04/23/2010 4:54 PM
what is hp value for submersible pump with flow rate 16 liter/sec. and head 6 meters ?
Pathfinder Tags: Pumps
Re: submersable pumps
04/24/2010 5:16 PM
Egypt
thanks
04/24/2010 12:21 AM
About 2-3 hp, depending on the type of pump and its efficiency.
04/24/2010 5:18 PM
thanks tornado
Re: Submersable Pumps
04/28/2010 5:30 AM
If you please give me the equation used to give the hp?
04/28/2010 9:31 AM
ΔP*Q/η.
Please see post 8 for the verbal explanation of these terms.
Good Answers: 27
04/24/2010 4:27 AM
Hydraulic power = sgxHxQx9.81 in consistent units. Divide this by the efficiency of the pump and you should be quite close to the shaft power required to drive the pump.
I do not know what "hp value" means and not sure of you mixture of units (hp, m etc.)
I have no special talent. I am only passionately curious. Albert E
04/24/2010 5:21 PM
hp value is the motor horsepower value
thanks
Re: Submersible Pumps
04/26/2010 3:23 AM
The shaft power required by any fluid mover is the pressure rise multiplied by the volumetric flowrate divided by the efficiency.
04/28/2010 5:24 AM
thank you
Register to Reply 11 comments
Kaisan (1); peterg7lyq (2); PWSlack (1); saad_said_59 (5); Tornado (2)
You might be interested in: Utility Meters, Submersible Pumps, Flow Meters
