Hi I hope someone can explain this one to me.
I've just come back from fixing a powerless wall socket, the fault was a broken neutral conductor further down the circuit. Now when I first tested the socket with a test screwdriver both terminals lit up this would be explained by an appliance plugged in elsewhere on the same circuit returning the supply down the neutral with no where else to go so giving the appearance of two live conductors. Fine but when I put my multi meter across it Showed 415 volts! this is on a 220v single phase supply.
Once I found and repaired the broken neutral conductor the meter voltage returned to 220v and everything works fine.
Anyone know what could have happened?
