Previous in Forum: Question on Shackles   Next in Forum: Flange Facing Finish
Gear Alignment
04/25/2010 12:19 PM
Could someone help me,I would love to know wat the general and simple procedure is for the alignment of bevel gears mesh using the techniques such as smearing engineers blue on the gears and interpreting the results of the contact points vis the standards.
Re: Gear alignment
04/25/2010 12:31 PM
Takes experience.
Look here for some basics.
HowStuffWorks "How Gears Work"
Re: Gear Alignment
04/25/2010 11:46 PM
What is the profile of the bevel?
The straight bevel I am not much aware of.
However if it is spiral/ palloidal system, there are lots of literature available on net.
In brief the technique we use is
a) Put a thin prussian blue coat on the driving member (pinion)- we put on 3-4 consecutive teeth- both flanks.
b) rotate the pinion both sides (CW and CCW) 3-4 times.
c) Check the bl;us contact pattern transferred - you can have the information from pinion where the blue would have been removed (transferred to bevel).
d) Check the back-lash at the pitch-line diameter of bevel.
e) Adjust till simultaneously the recommended back lash and contact is achieved.
f) Expected contact can be obtained from the manufacturer's test bench pattern. Alternatively aim for almost center of the tooth length contact. The length of contact should be almost 1/3rd of the tooth length and centered on the rolling pitch-line.
