Previous in Forum: Kitchen Hood with Air Speed MUA   Next in Forum: Gear Alignment
Question on Shackles
04/25/2010 11:25 AM
Hi guys, is there any US standards for the sizes of shackles? I wanted to see if there are something I can use with the lifting lugs for an ASME vessel.
And one thing on the stresses in shackles, I see that there are 2 types, pin shackle and threaded shackle. Threaded shackle I am happy with because the pine is mated with the shackle, and thus the load is evenly distributed along the contact area between the pin and shackle. But as for the Pin shackle, the pin will always be a little smaller in diameter than the shackle hole in order for it to fit in easily, but then the problem is once the shackle is lifted, the contact area between the shackle and the pin is just going to be one straight line due to the diameter differences, so when using pin shackles, wouldn't the stress in the pin be ridiculously large even though only a light weighted object is lifted?
Thanks
Re: Question on shackles
04/25/2010 11:57 AM
It seems to me that both types work just fine. Don't over analyze something that has worked in a million applications. (And that's no exaggeration) I prefer screw pin shackles myself. Only two parts to keep track of.
Screw Pin Anchor Shackles
04/25/2010 12:10 PM
I been here before, I do not have the direct hyperlink but I did a quick google you should find it on this site for stresses, but you'll have to search for it on the site. I'm sure its there.
I also did a lifting lug program in MS-Excel, and all the stress calculations I did, I used the cross sectional area of the pin through the lug itself, and there is of course play there, initially a line of contact between the pin itself and the thickness of the lug.
My experience is I notice every new or green engineer will over analysis everything until its unrecognizable only to fail anyways
these calculation were as per ASME requirements, if your interested in it, PM me with your email address and I'll email it to you.
p911
04/25/2010 7:26 PM
US shackles are typically designed and tested to ASME B30.26:
http://www.techstreet.com/standards/ASME/B30_26_2004?product_id=1221065
On one hand - good for you for thinking and enquiring about pin hole sizes and contact stresses.
On the other hand - you may* be over-analyzing/thinking and needless worrying.
*see further below
The famous phenomena that you seem to be asking about is Hertzian Contact Stress (any internet search engine will give you more than you can read)
There have been NUMEROUS studies (one classic one is - ASCE Transactions, "Pin-Connected Plate Links," by Bruce G. Johnston, March 1938) and tests regarding these questions, that is, pin/hole sizes - particularly when airplane design was being optimized in the mid 1900's . You should (but not overly) be more concerned about the pin diameter within the overall lug hole, rather than the pin in the shackle & even more so worried about pin bending than contact stress.
Quoted from "Proposed Design Criterion for Vessel Lifting Lugs in Lieu of ASME B30.20":
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=JPVTAS000129000002000326000001&idtype=cvips&gifs=yes&ref=no
"Most load resisting members are designed on the basis of
stress in the main body of the member, that is, in portions of the
body not affected by the localized stresses at or near a surface of
contact between bodies. In other words, most failures (excessive
elastic deflection, yielding, and fracture) of members are associated
with stresses and strains in portions of the body far removed from the points of application of the loads."
I have seen some company standards say that the lug hole should be no larger than 1/32" of the pin diameter, but, contrastingly: "Tests have indicated that the ratio of pin diameter to hole diameter has little influence on the ultimate strength of the lug material." - Quoted from the AISC Engineering Journal, Fourth Quarter 1991, "Design and Construction of Lifting Beams; David Ricker"
You would be well advised to discuss this in person will someone senior, and/or obtain any of the above quoted articles and read some, especially their references.
Good Answers: 150
04/25/2010 11:02 PM
I know the typical standard for the oilfield is pad eye hole to be 1/16" larger than the pin and no narrower than 75% of the shackle opening, using cheek plates (not preferred) or a thru welded tube (preferred), but this is sometimes problematic due to the thickness of the paint coatings that are often used. after all the paint and primer, the hole is often so tight that you have to hammer the pin in.
screw type shackles are not used because it is too easy for them to back out, it also puts the root diameter notch of the thread in the load bearing area. the shackle type with the nut and the cotter pin are usually specified.
The issue of line contact is explained fairly simply. With line contact you usually get both elastic and plastic deformation (brinelling) of the pad eye which if the hole size is close to the diameter of the pin, results in a fairly large contact area while under load.
Who is John Galt?
Good Answers: 27
04/25/2010 11:03 PM
I would also add the two primary types of shackles are anchor and chain and both are available with a tapped leg for a threaded bolt, pin and cotter as well as BNC (bolt, nut, cotter). In that case, a threaded bolt is used but the thread length is such that when the associated jam nut is run to the end of the thread, it will not contact the shackle. A hole is provided in the bolt end, about 5/16" from the end for typically a humpback cotter.
The difference between anchor and chain shackles is a chain shackle has straight legs with the radius of the closed end 1/2 the opening whereas the radius of the closed end of an anchor shackle is greater than half the opening width.
A chain shackle is typically stronger than an anchor shackle in tension because the typical failure mode is pin or bolt bending which tends to spread the shackle opening.
12/15/2014 9:33 AM
as per standard given by DNV 2.7-1, shows that manufacturing tolerance will be -0%/+3% from actual value tabulated in the table. and also as per EN13889 shows f bolt manufacturing tolerance. Therfore, I usually design the pin diameter for the shackle to 5% larger than the tabulated values of shackle pin diameter. where 2% to take account for the painting thickness. It seems works well
Design And Drafting - namasral
Re: Question on Shackles
04/26/2010 12:00 AM
See Crospy_Shackles, (round pin type & screw pin type), and see how to select the required size as illustrated in example at page 4 of 13:
Example: For lifting lug with thickness 50 mm (dimension A), the selected shackle nominal size is 1-1/4" with working load limit 12 Ton per shackle.
Abdel Halim Galala (1); Anonymous Poster (1); Bluestone (1); lyn (1); namasral (1); phoenix911 (1); Rorschach (1)
You might be interested in: Shackles, Threaded Inserts, PIN Diodes
