Previous in Forum: Piping Engineering - Statutory Regulations   Next in Forum: Nylon Evlon Peek
Crude Oil Desalting
04/27/2010 7:51 AM
I want to know theory of operation of crude oil desalters.
Good Answers: 101
Re: Crude Oil Desalting
04/27/2010 12:44 PM
Okay, they work by desalting crude oil.
04/27/2010 5:33 PM
... but only in theory
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
04/27/2010 6:20 PM
Salts that are frequently in crude oil are calcium, sodium and magnesium chlorides. If these are not removed from the oil several problems arise in the refining process. As dvader1000 wrote, desalting is removing salt from the crude oil. The salt is actually in the water that is in the crude oil, not in the oil itself. Desalting is usually the first process in refining. Content is measured in pounds of salt per thousand (PST) barrels of crude oil, so less PST means higher grade refined.
Go green, use a solar powered light saber...
04/28/2010 2:42 AM
i want to know how is salt removed from crude (theory of salt removing not desalters job)
Good Answers: 61
04/28/2010 3:19 PM
Go here and read:
http://www.gastecheng.com/p_desalters.php
Do it once and do it right
07/02/2010 1:38 AM
The crude charge consist of oil and water and some gases.
The water is actually the salt solution from about 200,000 ppmv per pound of the salty crude
dilute with water - with emulsification during mixing - heat - Electrostatic separated water from oil - separate salty water
This crude charge is first heated (nominally about 60degC @ 10 bar) is first mixed with dilution water to further dilute the salt. Emulsifier may be added to assists the mix.
The heated emulsified crude then passes though an electrical field (30-30KV) here the water (conductive) molecules are separated from the oil. The oil rises while the salt water falls.
The water is now removed with the salt.
Gas given of are vented or recovered.
There are many other aspects of the treatment to consider.
- oil viscosity
- Caolescense
- Electrical gradient
- proximity of electrodes
- polarity of electrodes
- electrical frequency
- droplet sizes
- chemical demulsification
- temperature and pressure of the crude charge
- types of controls
- mixing thoroughness
- composition of the crude charge
Well, that my $1 worth.
leow
singapore
Register to Reply 6 comments
Anonymous Poster (1); design2000 (1); Doorman (1); DVader1000 (1); Matt Skywalker (1); PennPiper (1)
