Previous in Forum: Eng.Mujeeb.Dubai   Next in Forum: icu and ics
Help with Program Code?
04/29/2010 2:51 AM
Hello;
This is my program; and it is not work.
the main Idea fo my program that; when any input of A0,A1,A2 change.
the PIC 16F877A, must make a pulses at the Outputs B0,B1,B2 if the input B3=0.
the Pulses is like this on (300ms) off (300ms) as appear in the program
#include "D:\cc\d\main.h"
int check_change();
void menu();
void end();
void cursor();
int which_MSG();
int8 sen1,sen2,sen3,i;
void main()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);setup_wdt(WDT_18MS);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
sen1=input(PIN_A0);
sen2=input(PIN_A1);
sen3=input(PIN_A2);
start:
if (check_change()==1) //&& input(PIN_B3)==0 )
goto messaging;
else
goto start;
messaging:
sen1=input(PIN_A0);
sen2=input(PIN_A1);
sen3=input(PIN_A2);
end();
menu();
menu();
menu();
cursor();
cursor();
cursor();
cursor();
menu();
for(i=0; i<which_MSG(); i++)
cursor();
menu();
menu();
cursor();
menu();
menu();
cursor();
menu();
menu();
end();
goto start;
int check_change()
if( (sen1==input(PIN_A0)) && (sen2==input(PIN_A1)) && (sen3==input(PIN_A2)) )
return 0;
else
return 1;
void menu()
output_high(PIN_B0);
delay_ms(900);
output_low(PIN_B0);
delay_ms(900);
void end()
output_high(PIN_B1);
delay_ms(900);
output_low(PIN_B1);
delay_ms(900);
void cursor()
output_high(PIN_B2);
delay_ms(900);
output_low(PIN_B2);
delay_ms(900);
int which_MSG()
int8 s1,s2,s3;
s1=input(PIN_A0);
s2=input(PIN_A1);
s3=input(PIN_A2);
if(s1==0 && s2==0 && s3==0)
return 0;
else if(s1==0 && s2==0 && s3==1)
return 1;
else if(s1==0 && s2==1 && s3==0)
return 2;
else if(s1==0 && s2==1 && s3==1)
return 3;
else if(s1==1 && s2==0 && s3==0)
return 4;
else if(s1==1 && s2==0 && s3==1)
return 5;
else if(s1==1 && s2==1 && s3==0)
return 6;
else if(s1==1 && s2==1 && s3==1)
return 7;
what is the wrong???
Good Answers: 74
Re: Help with Program Code?
04/29/2010 11:56 PM
Wow
Its your program, at least that is what you claim. If any one here could find what is wrong with it, it would be theirs now, wouldn't it?
You hang in there Mate, Rome was not built in a day, Ky.
The Twain Has Met
Good Answers: 54
04/30/2010 1:46 AM
Sorry, I can't/won't help. We all have these problems, it's the act of solving them that makes us better and faster programmers for next time.
Break it down into smaller steps and see if each bit does what you think it does.
By the way,
return 0; etc
can be simplified a tad, try reading the inputs as a word and masking unused bits
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Location: Zagreb, Republic of Croatia (native name Hrvatska) ,EU, Europe
04/30/2010 3:22 AM
I would say for one thing that You do not check for signal change but only for signal state, as You have to save previous state of input lines and compare new state with this to see if there is change.
Then You have to add condition test of B0==0 even if You detect change on input lines, which is not there even if comment say it is........
Last but not least, I would do it using bits switching in control byte and test whole byte for change in comparison with saved state of control byte.
If there is change and B0==0, then all You need to do is to have test to check which bit is on and send corresponding pulse on output line.
That way You get all combinations covered very simply without need for testing which it actually is, else for all Your numbered combinations You have to have same combination of outputs.
Now only question is whether You have to have signals in parallel when outputting them or You can do each one after another (I know about leech circuits that keep holding signal on line after getting them switched on, but I do not know what You are using as I am not Engineer of Electronic, just an old pro in programming that happened to have programmed controller for Magnetic Tape device that my friend has made for me).
I do not know if You can use threads in case signals have to go in parallel, but I guess it is not applicable here.
Main rule in programming is to make it as simple as possible, and in my time also with as few instructions as possible.
Sorry that I have no time to go over this program in details, and I was not programming in C for at least 20 years, so I am little rusty in that department :-))
Per Aspera ad Astra
04/30/2010 4:06 AM
Sorry, I wrote >>test of B0==0 << when it should have been >>test of B3==0<<.....
Another advice: we were testing program on the paper in old times, where You write table with names and state they have, and then walk trough program one instruction at time and see if it do what it is supposed to do. Make sure You set and test all combinations of input and check whether You get appropriate combination on output....
Then also You can add simple routine that would generate all combination of inputs and let program run on those inputs, with printout of inputs and outputs which You can check for correctnes.......
So when You are sure it is all working correctly, you remove input generating routine and output printing, and You have program You need to do whatever it is.........
Per Aspera ad Astra
04/30/2010 4:20 AM
I don't have any knowledge experience or real understanding: but,
What delimits what happens in the for loop?
Should this:
cursor();
menu();
menu();
cursor();
menu();
menu();
cursor();
menu();
menu();
end();
goto start;
Look like something like this
cursor();
menu();
menu();
cursor();
menu();
menu();
cursor();
menu();
menu();
end();
goto start;
04/30/2010 3:10 PM
Yes, that goto in a loop is mistake definitely!
But this is also syntax error to forget to write parentheses
(IF it is "C" language) so this program is not compiled also.........
Test on B3==0 should be uncommented.
Subroutine labeling/names are badly chosen
(end(), cursor(), menu()) as names do not reflect
function performed and therefore create confusion.
Then instead
goto messaging
whole program part under messaging:
should be put there instead.
This is because messaging is not referenced anywhere else,
so it is not necessary.
It is not explained why pulses on some lines are repeated
different number of times, and program has no way to
finish working as it always cycle back to "start:"
this is bad practice to set condition for end of loop on function
result that could change, as compiler should execute function
which_MSG()
each loop pass before comparing it to i, so if returned value
is changed, for can loop forever or one or more states would
be skipped as only highest value would be used to finish the loop.
But, this depend on frequency of state changes.
So better practice would be to assign value of message to variable
j==which_MSG() and then use this variable to control the loop.........
for(i=0; i<j; i++)
Still it is not clear why same sequence of pulses should be repeated
according to message value.........
Obviously this is a homework only without practical value, and we should have not interfered with our Guest learning process :-((
Per Aspera ad Astra
04/30/2010 6:56 AM
One obvious problem is the Goto jump in the for loop. Try to write the program without goto to get away from the spaghetti logic.
ffej (1); Henrik14 (3); ky (1); Randall (1); Rixter (1)
You might be interested in: Eddy Current Probes, Machine Vision Systems, Chuck Jaws
