Previous in Forum: Help Me Name My Institute   Next in Forum: L1, L2, L3 and N Main Busbar Arrangement in LV Switchboard
17 comments
Transformer Question
04/29/2010 7:18 AM
A transformer of 2 MVA , 6.6/0.433 KV and percentage impedence of 6.5 % is supplied with 0.433 KV on primary side(i.e 6.6 KV side0 and secondary side(i.e 0.433 KV side) shorted.Then what will be the exact current in primary and secondary side?
Re: Electrical,transformer
04/29/2010 7:22 AM
Whatever it is, it should be enough to operate the circuit protective devices recommended in the transformer manufacturer's manuals. After that time, it will be zero.
04/29/2010 7:26 AM
Sir,i want to know about the current.So please calculate and send it.
Regards
04/29/2010 7:27 AM
6,6 kV x 6,5 / 100 = short circuit voltage and at with this voltage while supplied nominal current will be circulate from winding of transformer
04/29/2010 7:39 AM
Is that before or after the circuit protective device has operated?
04/29/2010 7:53 AM
Before the circuit protective device operation.
05/04/2010 9:05 AM
What is the circuit protective device set to trip at?
Re: Transformer Question
04/29/2010 8:18 AM
Dear Sir,
As I have understood your wordings, for an iuput voltage of .433 Kv
on primary side , the voltage ( open circuit) will be 28.47 V and the % impedance
being 6.5 the short circuit current ( secondary side) will be 437.04 A.On primary
side this will be 28.67 A. Please correct me if I am wrong.
04/29/2010 11:18 AM
Once again i am writting down the question.
A transformer with following details is given.
2 MVA ,6.6 KV/0.433 KV(no load)
% impedance(Z)=6.25 %
primary current=175 amp
secondary current=2666.7 amp
Now on primary side(i.e on 6.6 KV side),0.433 KV is applied and secondary side is shortcircuited.then with this condition what will be the primary and secondary current.please explain your answer with details.
regards
04/29/2010 2:52 PM
Primary current = 160A
Secondary current = 1928A
NOTE - very dangerous when attempting to do as a practical test!!!
04/30/2010 1:13 AM
Thanks sir,but will you please explain,how you got these answer?
regards
04/29/2010 11:49 PM
Transformer % impedance is 6.25%
Means at 6.25 % of short ckt voltage full load current will flow in transformer
short ckt voltage = 6600*6.25/100=412.5
at 412.5 volt secondary current will be 2666.7amp
for 433v it will be (2666.7/415) x 433=2782a
never do this in practical .
04/30/2010 1:16 AM
thanks.Please explain your answer in details.
regards
04/30/2010 5:03 AM
% impedance refer to the pecentage of voltage applied to transformer atwhich full load current will flow in the transformer with one winding short circuited.
hope it will solve your query
05/04/2010 9:06 AM
Why would anyone want to do this?
Good Answers: 11
04/30/2010 10:00 AM
Simple approximations:-
Full Load Current = Tx VA / (SQRT(3) x Voltage) assuming normal 3 phase system
FLC = 2,000,000 / 1.73 x 400
= 2890 A (Approx. for 400V nominal)
= 2669 A (Approx. for 433V)
You can choose, but if you want to know approx. short circuit current, then divide FLC by impedance = 2890/0.065 = 44461A (50KA rated board required).
Stand well back when you switch it on to test, just in case you don't believe me.
If you supply primary side (6.6kV) with 433V, secondary will be about 28V. Don't short that out either.
rogerggbr
05/01/2010 10:59 AM
Thanks, but i want to know about the value of primary and secondary current.
Regards
Good Answers: 11
05/03/2010 11:48 AM
The maximum currents are the same whatever voltage is used, due to the design of the transformer i.e. copper size used, or in this case around 2500A secondary, 160A primary, before overheating. If you mean value of current under short circuit conditions, again this will be limited by the copper etc. Perhaps you could explain your purpose behind the question.
rogerggbr
Register to Reply 17 comments
Anonymous Poster (3); krazzycurrent (6); PWSlack (4); rogerggbr (2); smruti ranjan (2)
