Previous in Forum: Chinese 600 MW Dongfang Steam Turbine   Next in Forum: Alternative Material to SB:L73
Problems With Low Vacuum in Condenser
04/30/2010 2:37 AM
If we use low vacuum in condenser what will be the problem?
Re: mechanical
04/30/2010 3:11 AM
It depends upon what the condenser is doing, which isn't stated in the post.
Re: Problems With Low Vacuum in Condenser
05/05/2010 12:17 PM
Low vacuum i.e high absolute pressure in the condenser will deteriorate the performance. Overall efficiency will reduce, More heat will lost in condenser. low vacuum means high exhaust hood temperature, for which last blades are not designed.
08/30/2011 11:28 AM
Dear sir..!!
plz tell me what to do when the low vacuum problem persists in a 250MW or 500MW thermal plant.
06/20/2017 11:16 AM
Your issue is “If we use low vacuum in condenser what will be the problem?”
I think you are referring to a Power Plant. If it is so, low vac. means the heat drop per Kg. of Steam will be less – Refer Mollier Chart or steam tables and for the same load, the steam consumption will go up. If the steam supply or flow is not increased, the inlet steam pressure at turbine will fall down forcing the load to be reduced.
If it is a process system, where boiling is the function, the evaporation rate will fall down since the boiling temp. of the fluid will increase and over-all evaporation rate will fall down.
DHAYANANDHAN.S
Register to Reply 4 comments
dhayanandhan (1); Hari Ram Narvariya (1); prasoon s (1); PWSlack (1)
