Previous in Forum: Non Contact On-Off Status Monitoring of Motor   Next in Forum: Gulf of Mexico Oil Spill
High Strength Anti-Slip Grip Material
04/30/2010 3:47 AM
I threw this into general discussion because I can't decide between Manufacturing, Material Science, and Mechanical Engineering.
We have an application here where we carry gravure cylinders around on automated vehicles. Our gravure cylinders are heavy (2000lb) cylinders that have a shaft on both ends that is used to turn the main cylinder body. Due to machine interface issues with equipment that loads and unloads the automated vehicles, we cannot use a mechanical stop that will prevent the cylinders from sliding on the vehicles. Each end of the cylinder shaft (smooth steel) rests on two rollers (cam followers) that allow the cylinder to be rotated so that the surface may be inspected. I'm interested in a high strength, high friction material to either machine the rollers from or to coat or cover the rollers with that will provide improved friction to mitigate the problems we have with cylinders sliding on the vehicle. The current roller material is HDPE.
Thanks!
Re: high strength anti-slip grip material
04/30/2010 7:39 AM
I have read your description over and over, but I can't understand your problem.
In what direction is the motion of the cylinders on the vehicles? Is it axial motion that is the problem?
The first thing that does come to mind is some kind of rubber.
04/30/2010 9:35 AM
If stops at the end of the shafts are out, as I assume that stops that contact the end of the roller body are, I think something like an EPDM coated roller, as you suggest, might work. That's a lot of point contact pressure though.
05/03/2010 6:56 AM
yes, axial motion. I apologize for not making this clearer. The rollers lie in the same orientation as the cylinder body so that the cylinder can spin on the rollers like a pig on a spit. The only thing keeping the cylinder in place is the friction of the cylinder on the 4 rollers.
Basically, the material needs to have high friction and be strong enough to withstand ~500PSI.
Good Answers: 58
Re: High Strength Anti-Slip Grip Material
05/01/2010 3:44 PM
Safety tread for steps is peel and stick. When it wears out, it can easily be replaced.
mike k
05/03/2010 7:06 AM
It's worth a try. We aren't risking more than a few bucks.
I'm digging around for similar products that use diamond dust that could be more likely to withstand the pressure.
I really appreciate everyone taking the time to help out. This problem has been a real nuisance. It's one of these issues that was never addressed because two critical vendors were playing finger bang (ie pointing at each other) and it isn't a show-stopper, just a nuisance.
Anonymous Poster (2); lyn (1); mike k (1); morrie (1)
