Previous in Forum: Counter with Printer Option Needed   Next in Forum: Plastic FIBC Bags
RFID in Piping Spool Fabrication
05/01/2010 1:03 PM
I am exploring the idea of using RFID in the fabrication of piping spools for large value projects. If you have implemented/ used such a system would you please share your experience? Also what about the costs involved?
Re: RFID in piping spool fabrication
05/01/2010 1:46 PM
A Google search on "rfid tags cost" turned up quite a bit of information that you might find useful. If the tags are simple (small memory) and ordered in bulk, they may cost as little as US$0.50, but greater complexity and low-volume orders will cost more per unit.
Hobbies - DIY Welding - pipewelder
Re: RFID in Piping Spool Fabrication
05/02/2010 5:09 PM
I looked at some of the RFID sites and see that they have so many different ways to identify most any item someone can get a tag attached to. I just can see how installing these things in piping spool pieces would be a benefit to anyone. it is th weld that is usually scrutinized and because of the way most pipe is handled, staged and repaired in the field I would be afraid that most of the tags would not last and/or be damaged until production started on the system.
pipewelder
Register to Reply 2 comments
You might be interested in: RFID Software
