Re: What is the Difference Between "Metering CT" and "Simple CT"
05/03/2010 12:28 AM
Hi
A metering CT will be of higher accuracy class may be of <0.5% or better typically 0.2% (most common for this purpose).
A general CT can be of >1% accuracy, may be ok for protection circuits or for indication of current in the monitoring panel, not for accurate measurement purposes.
05/03/2010 1:11 PM
very generally saying:
metering cts have better accuracy at rated current and below and saturate quickly and can be set to saturate say at 200%.thus protecting sensitive meters under fault conditions.protection cts generally have comparitively inferior accuracy at rated current but can be set to reproduce currents as high as 20-50 times or even more with about 5-10% accuracy.
metering ct function is important when there is no fault but protection ct performance is important under fault conditions.
Better not count the cent if the risk is many many dollars.
