Previous in Forum: Light Test...   Next in Forum: Slow it Down
Engineering Fields - Aerospace Engineering - Retired South Africa - Member - The Rainbow-nation Engineering Fields - Engineering Physics - Relativity & Cosmology Popular Science - Cosmology - The Big Picture!
Good Answers: 69
Centrifugal Force
05/04/2010 5:12 AM
In my Bog entry on relativistic sling forces, a guest asked a question about the forces if the whole sling consisted out of a series of small 'force gauges' of negligible mass. It is an interesting, but tough question!
I am thinking about the relativistic implications, but, can someone please help with the 'plain old Newtonian forces', if those gauges have identical masses and we put no mass at the end of the string. In other words, how would each gauge register the forces when such a 'sling' of n serial gauges (masses) is swung at an angular velocity ω=dθ/dt?
To make it as simple as possible, assume that there is a gauge at the origin (r=0), ignoring its mass contribution and then n point masses, each of mass m, separated by distance r/n, for a total distributed mass of n x m, i.e., i runs from 1 to n. Now find the force Fi as a function of r and m.
I'm sure that most engineers working with rotating things will now how. It is essentially the stress in a cable that is swung in a circle, so I suppose a smoothly distributed mass will also do. Any ideas?
-J
Pathfinder Tags: Centrifugal force
Good Answers: 183
Re: Centrifugal Force
05/04/2010 6:50 AM
If you consider a distributed mass "m" [kg/m] the force measured at radius "r" will be:
F= ∫(m*dr)*r*ω² integral from r to R where R= radius at end of string.
The result (in classical mechanics) will be F(r)= m*ω²*(R²-r²)/2.
The string supports the sum of forces required to maintain the masses on the circular path since they have the trend to follow a straight trajectory. The string is loaded with a centrifugal force because on the masses must act a centripetal force for the circular path.
Good Answers: 69
05/04/2010 9:43 AM
Tx nick name, just trying to understand what you did. With m specified in kg/m, and I calculate it for the last meter, the applicable mass is just m, right? Now if R is fairly large, it means that R2 - r2 ≈ R2 and F(R-1) ≈ m*ω²*R²/2, which somehow does not look right. Should it not boil down to just F(R-1) ≈ m*ω²*R?
What am I missing?
-J
Good Answers: 183
05/04/2010 11:33 AM
The units! "m" being in kg/m it is NOT a concentrated mass. When you compute for a concentrated mass the radius is the distance between rotation center and COG of considered mass. In the way you put it would be F(1)=m*1*(R-1/2)*ω².
When the mass is uniformly distributed the mass element one has to consider is m*dr this is the reason I put it between brackets. This mass element is at the distance "r" to the rotation center thus the element of force will be dF=(m*dr)*r*ω². If you want to know the force generated in the string by the mass between r and R you must integrate the elementary force as:
F=∫dF from r to R → F=∫(m*dr)*r*ω² = m*ω²*(R²-r²)/2
Now let us look at the units: [m]=F*L^-1*T^2/L; [ω]= T^-1 ; [R²-r²]=L^2
→[F]= F* L^-2*T^2*(T^-1)²*L^2 = F so that the equation is CORRECT!
If you want to introduce the influence of v/c it is possible → dm= dmo/K where K is the correction factor which affects the mass as function of the speed at the considered level. "dmo" is the "static" mass element.
I hope that with those explanations all is clear if not I am every time available for more. If needed you may redirect the one who put the question to me.
Good Answers: 69
05/04/2010 1:12 PM
Tx again nick name, as Codey pointed out, I've made a silly mistake with my "Now if R is fairly large, it means that R2 - r2 ≈ R2 and F(R-1) ≈ m*ω²*R²/2".
Your equation does in fact give F(R-1) ≈ m ω² R for my example, as expected.
I will now contemplate the relativistic implications further along the lines that you suggested...
-J
Good Answers: 137
05/04/2010 12:13 PM
Hello Jorrie
I agree with Nick's result F(r)= m*ω²*(R²-r²)/2. If you put r=R, F=0, as expected. If r=0, F=m*ω²*R²/2.
Considering the last meter, r=R-1. I think where you're going wrong is saying R>>r, implying R²-r² ≈ R². If R is large and r=R-1, R is not >> r, they're fairly close. Putting r=R-1, F(R-1)=m*ω²*(R²-(R-1)²)/2=
m*ω²*(2R-1)/2. If R>>1, F≈m*ω²*2*R/2. Alternatively, by factoring, R²-r² = (R-r)*(R+r). R-r=1 and R+r=2R-1≈2R.
Also need to be careful with units. It looks as if a length dimension has disappeared but of course it hasn't or there'd be something wrong. Strictly speaking it should be F(R-1)=m*ω²*(2R*1m-1m2)/2.
Cheers......Codey
Codemaster (1); Jorrie (2); nick name (2)
You might be interested in: Mass Spectrometers, Pressure Gauges, Strain Gauges
