Previous in Forum: Discolourization of PVC tubes   Next in Forum: check valve - solid stellite
17 comments
Removal of Nickel Ore Stains / Footprints
05/05/2010 4:45 AM
How can I clean a large area, where Nickel Ore used to be stored? This is a painted steel surface.
Standard alkaline cleaners will not help. Even if I remove everything with high pressure water, there are still some yellowish footprints that have been soaked in the surface.
Please, does anybody know a proper method for complete removal of Nickel Ore? If not, anybody knows how to remove the yellowish footprints (stains)?
Pathfinder Tags: Nickel Ore
Good Answers: 60
Re: Removal of Nickel Ore stains / footprints
05/05/2010 6:13 AM
do you have access to google ?
05/05/2010 6:15 AM
Of course... I did not find anything. Only some methods for dissolving nickel alloys etc.
Good Answers: 60
05/05/2010 6:35 AM
http://uk.ask.com/web?l=dis&qsrc=999&siteid=41627711&o=41627711&q=Removal+of+Nickel+Ore+stains+%2F+footprintsremoval+of+nickel+stains&ifr=1
05/05/2010 7:01 AM
I don't get it. It just returns a simple search from Jeeves with nothing new.
05/05/2010 8:28 AM
Strip and repaint.
05/05/2010 8:32 AM
Stripping isn't the right solution. Harming the paint of carbon steel a little is ok, but I'm talking about a whole ship's hold.
05/05/2010 9:43 AM
Why isn't stripping and painting the right solution? Is that too 'nice' a finish?
What are you trying to accomplish? Are you converting a Handymax to a passenger ship? How clean and sparkly does the hold of a bulk carrier need to be?
05/06/2010 2:29 AM
You're right! It's a bulk carrier, turning from ore to wheat. And, as you may know, stripping is never the solution for the shipping companies.
It does not have to be sparky, but needs to be clean and without stains, so that it'll pass the investigation.
Re: Removal of Nickel Ore Stains / Footprints
05/05/2010 10:03 AM
Have you tried bleach? Cheap enough and available enough to try. Above that, maybe 30% hydrogen peroxide, but make sure to read the MSDS for proper handling procedures.
05/06/2010 2:32 AM
I've tried sodium hypo 12% (bleach), not working! Hydrogen peroxide seems promising! It should be combined with bleach? Or stand alone application?
How does it interact with painted surfaces? Discoloring like bleach? Stripping?
Should I use it in combination with other chemicals?
05/05/2010 10:58 AM
Which type of nickel ore? How much Cu or Fe is included? Do you know what caused the stains?
Would this "ore" look like dirt to the uninitiated?
If "nickel ore" is all you know, then, strip and repaint is still my answer.
Sorry
05/06/2010 2:35 AM
I looks like mud. It is the ore, just extracted from the mine (Africa). It may have any composition. Sorry, stripping not an option.
Good Answers: 150
05/06/2010 9:14 AM
Could you paint over the original paint layer without stripping? I know that probably has every coating guy on the planet rolling over in his or her grave whether they are dead yet or not, but if stripping is a non-starter......
Who is John Galt?
Location: Polyonics, Inc., 867 Rt 12, Westmorelane, NH 03467 603-352-1415
05/06/2010 9:45 AM
If one assumes that the stain is due to the presence of nickel (and other metallic) oxides, you might think about using a solution which contains chelating agents, such as EDTA. These compounds will form water soluble chelates with metal ions which can then be dissolved (washed). That's the next chemically logical approach..oxidation didn't work (bleach) since (hypothetically) the ionic species are already highly oxidized.....I'd be interested in knowing if this shows any promise at all.
05/06/2010 9:00 PM
First thing I think is to ask what kind paint is on the floor. If it is epoxy coat the you may try delute nitric acid solution then a cleating agent like HEDP (phosphonic asid). Nitric acis dissolves nickel ores or nickel metal.
You may also try a special formulated nickel strippers which you can easly find from electro plating chemical suppliers.
Hope this can help.
05/07/2010 10:56 AM
One other thought..the key is to try to identify what the composition of the yellow stain is...You can use a portable XRay Flouresence (XRF) device to identify the chemical/elemental differences between the stained and unstained area. This (hopefully) will give you a clue as to the composition of the stained area relative to the unstained area. THEN..perhaps..you will have evidence to guide a cleaning procedure. Seems more orderly than "hit or miss". You should offer this challenge to manufacturers of portable XRF units...perhaps a great demo will result in their selling you an instrument? Good luck.
Register to Reply 17 comments
Anonymous Poster (1); Doorman (1); drxai (6); lyn (2); Mikerho (1); peterg7lyq (3); polyonx (2); Rorschach (1)
