Previous in Forum: Wind turbine   Next in Forum: Reduced Bore Gate Valve
Fire Tube Boiler Maintanance
05/05/2010 5:23 PM
What is the best procedure of acid cleaning a Fire tube boiler (on the water side)?
What is the recommended acid to use and at what concentration?
Re: Fire Tube Boiler Maintanance
05/06/2010 3:21 AM
At all times, follow the boiler manufacturer's maintenance instructions. If they aren't in the manual that was supplied with the equipment, contact the manufacturer directly for advice.
Good Answers: 19
05/06/2010 7:03 AM
can a specialist who does this as a business - stay away 1000 ft when he is doing it.
After - get a reliable softening plant and hire a consultant to check and advice on chemical dosage every month.
05/07/2010 2:31 AM
A reply to your question depends on why you want to use acid clean on the water side?. Is there a build-up of scale due to inadequate water treatment? -and if so what is the scale composition?. You have already been given the correct answers for your standard of knowledge on the subject.
05/07/2010 9:39 AM
There are people who specialise in such cleaning for removal of scale build up. You need them to check and recommend their process with a guarantee against damaging the boiler furnace tube during the process.
On your own risk and without any guarantee of any kind, use a mild acid like citric acid diluted to 1 in 100.....you need to fill the boiler to cover the tube and leave it for some time. A little heating to 50-60 deg C will help accelerate. You might need to repeat. AT THE END, SOME METAL WILL BE DEPLETED FROM ANY EXPOSED PARTS (not covered with scale).
05/18/2010 5:20 PM
I actually made an experiment, by soaking 2 boiler tubes in an HCL(concentrated straight from the supplier i.e 33%) bath, 1 clean, un scaled and the other had heavy scaling. My experiment took 15hour(with constant monitering) & the results were overwelming, the unscaled was un attacked ( at least observing with the eye) and the scaled one was cleand!
07/04/2010 6:21 PM
along with the previous comments i should suggest that you consider, it will take a long process to clear the boiler of the smell after an acid cleaning.. i mention this if your considering this in a bakery environment. proofing doughs.
klearzen
Register to Reply 6 comments
ducon (1); Evans Mahopolo (1); klearzen (1); LAA_Lucke (1); Neil Kwyrer (1); PWSlack (1)
