Previous in Forum: Belt Conveyor Speed?   Next in Forum: Gear Pump Lubrication
9 comments
PTFE FLUOROGOLD - Joining sheets
05/06/2010 9:27 AM
Hello, I'm a Mechanical Engineer from Australia. I am involved in a project that requires the use of a very large PTFE slide plate, basically a large pipe support with stainless steel plate welded to the pipe support and slides on PTFE. The support is exposed to sun light, dusty dry conditions and very large lateral movements, upto 600mm and 290KN of compressive load. I have beeen advised to use PTFE - Fluorogold.
The problem is sheet sizes are only available in 600mm square. We need a length of PTFE 1,850mm long and 250mm wide. I have been told to "dovetail" join the sheets together. I am worried that due to the comprssive load and deformation of the PTFE, the stainless steel sliding over the join will hit the join and basically tear the join apart and fail. It is bonded to a carbon steel plate.
Should I be worried? Is the joining method OK? Is there another method of joining?
I could bond the PTFE to the underside of the pipe support, although I am not sure of the stainless steel plate, this would have to be 1,850mm long and 50% of the area will be exposed to the environment and not sure if the stainless will degrade in the sun and lower the co-efficient of friction.
Are there any websites that could help??
Sorry for the length of this question and appreciate your help....
Thank you.
Good Answers: 114
Re: PTFE FLUOROGOLD - Joining sheets
05/06/2010 10:31 AM
The Fluorogold is always bonded to a substrate in the Fluorogold shop. I don't know why yours has to be so big, 290KN is roughly 65k. Without neoprene backing, Fluorogold is good for about 2k depending on temperature, say 36 sq.ins, say 6"x6", 150mmx150mm. The top should always be a little bigger than the bottom, all round, including the movement. The bearing does not need to be as big as the support itself.
Split your bearing into two, each one having a single sheet on the bottom and a butted double sheet on top, the butt joint always being above the bottom sheet, whatever the movement.
Usually, I provided a sheet metal shroud in dirty configurations.
http://www.sepbearings.com/teflon-slide-bearings.html
http://www.sepbearings.com/media/fluorogold.pdf
05/06/2010 11:40 AM
Nothing to add, except, always enlist the help of the suppliers technical resources.
05/07/2010 12:56 AM
Thanks for the reply and website links. I agree the top should be bigger than the botton to keep the PTFE protected, however the pipes lateral movment is over +/- 600mm from the pipe centerline. These are large LNG pipes. It is not practical to make the top larger and there is no space to allow for a larger pipe shoe base.
The bearing area, stainless steel sitting on the PTFE is 580mm x 100mm and is to support a 290 KN load. The PTFE is exposed to sun light and as this is in northern Australia the design temperature is 75 degrees celcius.
I have recieved information form our supplier, although I would like to get other peoples opinions.
I guess the only option is to source a supplier than can produce PTFE more than 600mm square. Pitty we can't restrict the pipes movment with line stops.
Good Answers: 114
05/07/2010 3:22 PM
I have a little difficulty in imagining a situation where you cannot have a wider shoe, but can accommodate +/-600mm of lateral; movement. Of course, there is a lot more that I don't know of the situation.
Years ago, I had a stainless steel version of a roller skate attached to a pipe shoe in lieu of a sliding bearing for reasons analogous to yours. As these are big pipes, they should be able to push small wheels through accumulated dust and sand.
Good Answers: 109
05/07/2010 2:43 AM
Hi,
dovetailing is not a good idea.
There is no need to join bearing plates.
As you can support with the tips of your 5 fingers a dish - the same way you can support your thermally moving pipe by as many bearing pads as suitable.
Each pad has to be flexibly mounted so that the vertical load is distributed regardless of tolerances. Optimum pad size to be discussed.
And each pad has to be horizontally secured against friction forces.
Depending on dust conditions it may be highly advisably not only to follw above recommendations but may be to think about a dust- and sand-"tight" enclosure.
Put down on paper with signatures and dates your bosses needs and your objections, he will forget what he ordered you to do - if anything fails.
RHABE
Good Answers: 53
05/07/2010 3:14 AM
You can cast your own sheet. If you can find a volatile organic solvent for PTFE You can cast youR own sheet by making viscus solution of PTFE and casting it in desired shape.
You will have to leave it for sometime at a warmer temp at which solvent can evaporate. more is the viscosity less will be shrinkage.
05/07/2010 10:35 AM
Never heard of such. I think the key is, "If you can find a volatile organic solvent for PTFE". I'm not aware of any such liquid, are you?
05/07/2010 9:45 AM
Fluorogold is manufactured by Saint-Gobain Performance Plastics and is available in continuous rolls etched or unetched for bonding in thicknesses up to 6.35mm (.25") and typical widths of 304.8mm (12"), which can be slit to 250mm (9.84"). What thickness are you using?
05/08/2010 8:19 AM
Thanks AppsGuy for the reply. We are thinking of using 3mm etched on one side. (not sure of the imperial conversion). Using 3mm eliminates the doformation under compressive load (my load conditions are mentioned above (hopefully I have done the calculations right). We are using araldite 2 pac mix to join the PTFE to carbon steel plate, compressed and then placed in an oven for a certain time.
If there is no deformation of the PTFE we probably could use pieces of PTFE. I will have a look at the company you have mentioned. The worry is Australia is so far away and you have to factor in transport costs. There is a company in Sydney that makes it called Dotmar, I am currently finding out if they can make a continuous sheet.
Register to Reply 9 comments
AppsGuy (1); Corduroy (2); lyn (2); passingtongreen (2); rakesh_semwal (1); RHABE (1)
