can electrical engineer get B.O.E .mean boiler proficiency engineer exam .
if i get 2 years experience in operation & maintenance in HRSG BOILER 12 TON PER HOUR . SO please give advice for that and reference book for preparation .
Respected sir ,
i am very glad and happy to see your positive feed back . thanks
now please suggest Reference book and material for B.O.E . i am basically B.E electrical engineer having 12 years exp in plant maintenance . now a days since 4 month i look in to boiler and gas turbine as a site manager so i need your help
please.
Happy to see your Deep Intrest for BOE EXAM. FOR YOUR EXPERIENCE AND INTREST PASSING BOE EXAM IS VERY SIMPLE. Please do the following.
1. You have not mentioned in which State you are working. In which state you want to appear for the B.O.E Exam.
2. You approach the OFFICE OF THE DIRECTOR OF BOILERS,OR CHIEF INSPECTOR OF BOILERS (as the case may be) where you want to appear for BOE EXAM, and find out the Exam schedule and take the application at the appropriate time and apply enclosing the service certificate etc as found in the application. SEE THAT YOU ARE SATISFYING THE CONDITIONS STIPULATED IN THE APPLICATION, and appear for the Exam.
3. There are several books very deep in design as well as operations. It is not known whether you are intrested in Design or Operations only.
Try to get the previous exam question papers and try to understand the nature of the subject involved. the topics covered are very wide ranging from design and construction of boiler, fuel and combustion, heat transfer, air-fuel ratio,water treatment,super heaters, economisers etc. etc. BUT NO NEED TO WORRY.
Try to get a book which deals in a QUESTION and ANSWER FORMAT for the entire Boiler Operation/Design. With your experience passing B.O.E with DISTINCTION should not be a problem. B.O.E Exam is simple. About 22 years back I was one of the EXAMINERS for B.O.E EXAMS.
Please provide your mail Id. and I may be helpful to you.
4. You may brouse many web-links/books/articles to match to your need by using google search or going to www.askjeeves.com, or any other search engines.
5. You may have 4 theory papers and one viva-voce.
Sir
I have applied for B.O.E from the state if Gujarat ( Bharuch). At present I am working in NTPC Ltd and i hace nearly 10 years of experience in boiler operation. I am working presently at Delhi.
Can you please tell me name of a few books which i could purchase. I have tried a lot but i have no i idea about wht to study and from where.
Regards
Samir Kumar Singh
email - removed - cr4 admin
Thank you for your interest, I'm from kerala, and i'd like to take BOE exam either in kerala or tamilnadu. I'm B.tech in mechanical engg. and working as site engineer for a boiler firm, in charge of erection and commissioning of their boilers across the south india.
wat are the criterias for appearing for BOE in tamilnadu?
and if possible kindly share some study materials required for BOE (krive_meen1@hotmail.com).
i'm ganesh and i am completed my diploma in chemical eng. i'm intrested to boe exam. but i don't have information about boe. plz send me detail information.
Just as you replied Jayesh100375 that passing of BOE exam is very simple, I would like to ask you some simple questions.
1) A boiler with no stamp. How would you size the safety valve.?
2) Two boilers were burnt with the same quality of coal & their flue gas analysis gave the identical reports. Are their efficiencies the same.? If yes, why.? If no, why not.?
Hope, you answer me these simple questions in mimimum possible time.
Your QUESTION can be viewed in TWO DIFFERENT ANGLE.
1. POSITIVE SIDE 2.NEGATIVE SIDE.
I TAKE YOUR QUESTION ON POSITIVE SIDE, and my reply is:
A BOILER WITHOUT STAMP SHOULD NOT or MUST NOT BE USED. The concerned Officer who accepted the Boiler without STAMPING should be questioned/action taken against him/terminate him and SEIZE HIS QUALIFICATION DEGREE/DIPLOMA
ON YOUR QUESTION FOR SIZING SAFETY VALVE THE REPLY IS on the BASIS ACADEMICAL ASPECT OR ACADEMICAL INTREST POINT OF VIEW ONLY - I reply.
1. Estimate the Heating Surface and MULTIPLY by the STANDARD for the EVAPORATION RATE. This gives the CAPACITY OF THE BOILER.
The Thickness of Drum. Bank Tubes, Super Heater Coils, Economiser Coils, Super Heater Steam Pipe going out of the valve etc. etc., can be measured/estimated. Apply the formula and calculate the Pressure and adopt the LOWEST of ALL THE PRESSURES as the Design Pressure of the Boiler.
Now Capacity is estimated, Design Pressure is estimated, and how to size the safety Valve is the next exercise. Super Heated Steam Pipe size is known, and hence AREA CAN BE CALCULATED. CAPACITY IS ESTIMATED and hence VOLUME of STEAM FLOW/SECOND is estimated. Using the Standard Velocity, based on these data, STEAM TEMPERATURE CAN BE ESTIMATED. HENCE SAFETY VALVE CAN BE SIZED.
COMING TO YOUR 2nd QUESTION " Two boilers were burnt with the same quality of coal & their flue
same.? If yes, why.? If no, why not.?" -
The ANSWER IS THE BOILER EFFICIENCY WILL NOT BE THE SAME. The same quantity of Fuel and the Same Flue Gas Analysis are not the ONLY CRITERION for BOILER EFFICIENCY. The other criteria are, as you also know - the Feed Water Temp., the Blow-Down Quantity, Radiation Level of the Boiler(s), F.D Air Temp., Flue Gas Temp. after Air Heater, The Furnace Leakages, HEAT TRANSFER CO-EFFICIENTS for Boiler Bank Tubes, Super Heater etc. etc., will come in to account - which may vary in the boiler(s) singly or severally.
ON THE NEGATIVE ASPECT OF THE QUESTION - I do not reply since you may get offended.
The delay in reply is due to the reason - I DID NOT SEE THIS due to pressure of work and out of station for several days. However, the delay is regretted. Any further quiery or doubt you can ask.
Really thanks Sir for the answers. The above questions were being asked for the American Boiler Proficient Engineers & so do I. I have many such questions & if you want, I'll ask them for the maximum so as to derive the most appropriate & correct answers for the same.
You can ask any number of question and you will get the answer from me or other CR4 MEMBERS. You can post the questions through the mail link available in the CR4 system, since after some time, no more posting will be accepted.
1) Where would you find the pressure piping stamp on a steam header of a
boiler that requires two (2) stop valves located 50 feet apart?
2) Before a person enters boiler, what do you need to do.?
3) Given: A 700 psi boiler drum, 36 inch diameter, and length 24
feet. What code would you reference to insure that a blow off tank was sufficiently
built to handle this?
4) After a repair has been made and inspected by the Authorized Boiler Inspector, what else must be done?
5) What is the HP required for a feed
water pump that is 80% efficient supplying a boiler with 200 psi?
6) With two boilers both at 100 hp one
operating at 50 psi and the other at 100 psi would both safety valves be the
same size?
All the above questions were asked in American Boiler Proficiency examination.
though we are eligible recent examination did by tamilnadu govt ,they did very tough quetion on applied mechanics and tough valuation too.
powerful persons voice only make the changes for better society.though i am confident on passing on applied machanics and with average of 70 for 4 subjects.
the result is fail.
i got 341/450 in energy manager exam which is also similar this BOE exam.like me many of my colleages got failed .pl guide us to come over this issue.
Dear My Self Nirmit Vyas I have two year exp in textile company in O&m Utility with 6ton/hour Boiler for process steam So plz guide Me I am Applicable for BOE exam Or Not My ID IS nirmit_vyas@atul.co.in
I AM NIPUN VADALIA FROM GUJARAT. I AM VERY MUCH INTERESTED ABOUT THIS B.O.E. EXAM.NOW I AM WORKING IN ESSAR POWER LIMITED AS A TECHNO HR. MY JOB IS TO GIVE TRAINING TO FRESH ENGINEERS. I AM NOT IN OPERATION OR MAINTANCE DEPARTMENT SO MAY I ELIGIBLE FOR THAT EXAM.
You have mentioned " I AM NIPUN VADALIA FROM GUJARAT. I AM VERY MUCH INTERESTED ABOUT THIS B.O.E. EXAM.NOW I AM WORKING IN ESSAR POWER LIMITED AS A TECHNO HR. MY JOB IS TO GIVE TRAINING TO FRESH ENGINEERS. I AM NOT IN OPERATION OR MAINTANCE DEPARTMENT SO MAY I ELIGIBLE FOR THAT EXAM."
The answer is NO. You should have experience in the Operation and Maintanance of Boiler, a minimum number of years prescribed by the Boiler Dept.
