Previous in Forum: 200 Ton Hydraulic Press   Next in Forum: Sources for superferritic stainless steel
10 comments
Trying to Use 1 Application CD for 2 Computers
05/10/2010 2:57 AM
i have bought a bitsat exam test runner .... i.e it consists of a cd-rom with a key to install the application.the problem is that my friend too want to take the model tests in that cd... so i write a copy of that original cd to a sony emty cd by using nero start smart software... the entire cd is copied but while i am installing the application with that copied cd i am unable to install the applctn WHEN I AM ENTERING THE KEY DISPLAYED ON THE ORIGNAL CD... the error is that THIS IS NOT A ORIGINAL CD-ROM....USE ORIGINAL CD..... please help me out .... the cd is 1000 rupees .. we cant afford tht much so to buy a 2nd orignal cd.... we cant share same cd bcoz it results in loss of time as both are preparin for same exam on same day... SO HELP ME BY TELLIN HOW TO INSTALL THE APPLICATION WITHOUT ORIGIANL CD...????
Re: computer plob
05/10/2010 3:28 AM
Oops.
You should have read the licensing provisions first.
Re: computer plob
05/10/2010 5:53 AM
so there is no other way to use the cd ????
Good Answers: 53
Re: computer plob
05/10/2010 7:38 AM
Did you confirmed from CD supplier if it is legal to do so? or have checked licensing agreement?
If its not legal to do so, in that case it is a kind of piracy and no one here will advice to so.
Re: computer plob
05/10/2010 7:44 AM
It is definitely not legal to do so. These are usually protected against this type of practices. It is definitely not ethical.
why the two can not do the preparation together?
Good Answers: 53
Re: computer plob
05/10/2010 7:51 AM
Yes that IS most certainly going to be case, But I wanted to hear it from OP so that he can realise the importance of issue.
Re: computer plob
05/10/2010 8:54 AM
The OP is young, this is the time he should distinguish between what is etical and what is not, and try to tread the straight path.
He should understand that, there is a lot of effort that has gone into making, what ever he is buing. There are $s spent. Now if everybody keeps on trying to get things free, who will tomorrow take the effort to make a new updated one?
BTW: Do you see the TATA tea ads? I really like the messages.
Good Answers: 53
Re: computer plob
05/10/2010 9:13 AM
This One? Too good.
Re: computer plob
05/10/2010 7:43 AM
You could not use that CD,right!
Good Answers: 38
Re: computer plob
05/10/2010 9:00 AM
Once the program is installed you should not need the CD. If the original is needed, that is what the vendor requires and your out of luck. Check the licensing agreement. Many programs are allowed to be installed on several computers that YOU own for ease of use. Normally it records how many times it has been installed and if you go over that amount you are denied access. Microsoft does this on almost all their software. Contacting them if you are the original owner, is probably your only option.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: Trying to Use 1 Application CD for 2 Computers
05/10/2010 3:37 PM
As others have said this product is likely only licenced for one computer at a time (see licence agreement in manual or on the CD), which is standard for almost all purchased software. Copying the CD with Nero won't work. Installing the program on your friends computer using the original CD and key may possibly work, but probably won't be legal, and may even invalidate your original key disabling the software altogether (again see end user agreement in manual or on the CD).
Since sharing the CD is not viable, I would suggest getting your friend around and using a single computer with the software loaded on to it either together or in turns.
Let the studying begin!
Register to Reply 10 comments
Anonymous Poster (2); charsley99 (1); DavidCart (1); harsha_iit (1); jack of all trades (1); rakesh_semwal (3); Tornado (1)
You might be interested in: MASK ROM (MROM), Optical Storage Media, Computers
