Previous in Forum: LabView   Next in Forum: Impact of Accelerometer Weight on Test
SIL certificate or prior-use
05/11/2010 4:10 AM
I read some SIS expert answers to some questions and I realized that no requirement for certification of field instruments anywhere in ISA 84.01/IEC61511 for field devices. What about logic solver??.
Also Field devices should be selected based on proven performance "Prior – Use" then why manufacturers pay money to get SIL certificate for their devices?
and how end user know that this device is proven performance in the operating environment simply how to Select field instruments and logic solver for Safety Instrumented?
Re: SIL certificate or prior-use
05/11/2010 12:36 PM
The SIL certificate is of no value. It is the Report that provides the basis for the SIL certificate that is the thing of value.
As to why manufacturers pay money to get a SIL certificate, one possibility is that they use it to increase sales.
05/12/2010 2:27 AM
What report you mean?can you show me example (link,or upload)
05/12/2010 10:31 AM
I think PWSlack answered the SIL Certificate question.
The issue with prior use, or proven performance, is that in order to be a SIL rated system, there is a requirement for maintenance and testing intervals, and records to be maintained. These records will indicate the frequency of replacement or the reliability of the components, which will give a "proven in use" history. The calculations for the computation of the SIL level treat all instruments (in general) the same, such as all pressure transmitters have equal PFD's, and all Temperature transmitters have the same PFD's. SIL level is changed by adding redundancy, or changing the frequency of testing, selecting different valves, and a few other things.
Logic solvers are classified as triple redundant, double redundant, trip amps, relays, dedicated safety rated PLC, and so on...there are only a few types to choose from, and each brand is treated the same since they have a common PFD range as far as the calculations go.
Selecting field instruments and logic solvers for a SIS depends on whether it is an existing system or a new system. In either case, a LOPA, Layer of Protection Analysis is performed to determine what SIL level is required based on a company's risk tolerance. After the SIL level required is determined, the existing system is analyzed to determine the SIL level and any changes required to raise or lower it are designed. A new system is simply designed to that SIL level. Selection of field instruments may be from a company's current inventory or it may be necessary to specify an instrument to meet the new design conditions.
Register to Reply 3 comments
a_m_shiha (1); PWSlack (1); shooter (1)
