Previous in Forum: AC Voltage Regulator   Next in Forum: Transformer
Reactor Transformer
05/12/2010 1:21 PM
What is a Reactor transformer? Why is it used?
Re: Transformer
05/12/2010 2:31 PM
Are these 3 (or more) transformer postings for a project, homework or some other purpose?
Re: Transformer
05/12/2010 2:36 PM
Does not a matter , we need useful reply.
Re: Transformer
05/12/2010 3:20 PM
Boy, I wish I had seen this comment #2 before I posted to your next thread!
AH! Less than 15 min. See ya bye.
Re: Transformer
05/12/2010 2:48 PM
The reactor is an element that can control the voltage and power flow in a power system. Its resistance in ideal is zero and in real is very low. The reactor is a wire that is turned around a core (the core can be magnetic material such as steel or it can be air or free space). When a current passes through it, a voltage will induced across it. The reactor works according to the Faraday law which says: If a varying magnetic field passes through a coil, a voltage will induced (made) on that coil.
Reactors / chokes / inductors / coils – often used for smoothing in rectifiers, reducing short-circuit currents, AC filtering, commutation in thyristors and high frequency switching.
different type reactors:-
arc suppression reactors, capacitor damping reactors,current limiting reactors,filter reactors,Neutral earthing reactors,shunt reactors
Re: Transformer
05/13/2010 3:29 PM
Thank you for the precise explanation...but i do have a question in my mind???
What type of reactors do we use in Transformers? Is it Arc suppression reactors or current limiting reactors or is it some other reactors? please reply soon..
Re: Transformer
05/13/2010 3:37 PM
Is it home work question ?
Re: Transformer
05/14/2010 12:27 AM
No, its not...
but can you help me out in getting the exact answer to my querry?
Register to Reply 7 comments
Alanvaderi (1); Anonymous Poster (3); Doorman (1); swapnajit99 (2)
