Previous in Forum: how to become a cbi   Next in Forum: Reactor Transformer
11 comments
AC Voltage Regulator
05/12/2010 11:55 AM
Hi to all
What is the best method to build a 3KVA /220V modern AC voltage Regulator(Sabilizer)
Thanks for your ideas.
Re: AC Voltage Regulator
05/12/2010 6:02 PM
Go with Ferroresonant Transformer.
05/13/2010 3:07 AM
Best method? Google and buy one, I suppose.
Good moaning!
Good Answers: 53
05/13/2010 3:58 AM
What is important cost or amount of precision in control?
05/13/2010 4:17 AM
Precision and efficiency.
Good Answers: 53
05/13/2010 7:41 AM
Ok.Servo should be good for you in that case.
05/13/2010 11:29 AM
What you mean for servo? Do you mean Rectifier/Inverter ?
Good Answers: 53
05/14/2010 5:05 AM
Servo controlled, you can google it, lot of information.
Good Answers: 27
05/13/2010 12:10 PM
It will be dependent on how much input voltage is varying and what will be the acceptable output voltage range?
vsar
05/13/2010 12:33 PM
input variation 15% , output variation must be less than 3%
Good Answers: 27
05/13/2010 3:09 PM
Sola transformers are readily available and more than satisfy your required specs. with +/- 1% output regulation.
vsar
05/15/2010 8:42 AM
Why have you asked this question twice on the same day in two different blogs?????????
Register to Reply 11 comments
Andy Germany (1); Anonymous Poster (3); Crabtree (1); rakesh_semwal (3); vsar (2); zacky (1)
