Previous in Forum: Difference between 4140 and 4140H steel   Next in Forum: Cat Training?
17 comments
Transocean - Tyranny of Depth - Does It Matter?
05/12/2010 1:31 PM
Does the "Tyranny of Depth" really matter if you take humans out of the equation?
If you take equipment normally used at the surface, enclose it in a chamber with an atmosphere just slightly higher than the outside ocean pressure, what are the depth limitations?
Equipment that you wouldn't be able to use:
- Closed cell foams
- Anything with a differential pressure. Example: Vacuum tubes
You would need to pick the atmosphere that you wish to use.
Taking those into account what other limitations are there?
Effects on:
- Hydraulic fluids and lubricating oils subject to the atmosphere you choose.
- Accommodation for items like cooling fans due to the increased gas density.
- How much electrical power can be delivered through an umbilical to drive the equipment.
- Consideration: Desaturating equipment on the way back up to save seals, etc.
If this were possible could you have an ROV garage at the sea floor to operate a remote base complete with desalinated water to wash down the equipment?
Could you bring equipment from the ocean floor inside the garage to work on it in a relatively friendly environment? You could potentially use commercially available industrial robots or CNC equipment inside the garage.
Re: Transocean - Tyranny of Depth - Does It Matter?
05/13/2010 5:02 AM
How many ROVs does it take to change a light bulb?
Food for thought?
05/13/2010 9:48 AM
? "Atmosphere"...? "...desalinated water to wash down the equipment?"...
Who needs an atmosphere? Why wash-down the equipment? Engineer it for the environment it'll be in.
Nothing is out of reach, if your *budget* can handle it.
Your dream/vision isn't thinking in terms of Cost-vs-Benefit yet.
What would you be doing with this "garage" on the sea floor? Harvesting manganese nodules...?
Good Answers: 150
05/13/2010 10:15 AM
Generally speaking hydrostatic pressure is not a big deal. It is the difference between the hydrostatic and the wellbore pressure that is the issue.
There are no humans at that depth. it is all done with ROV's which don't need much in the way of pressure containment (except for the control systems which are in a pressure vessel and are often pressure compensated with dielectric oil.)
Who is John Galt?
05/13/2010 11:02 AM
Actually we use closed cell foams at depth all the time. They just happen to have a very high concentration of glass microspheres. Google or Wiki syntactic foam.
05/13/2010 11:21 AM
Yes, syntactic foam does work well up to the pressure limitations of the glass microsphere collapse rating.
The atmosphere could be non-oxidizing such as nitrogen, helium or ??? That would potentially open the possibility of applying the vast majority of surface equipment for use within the enclosure.
The exotic materials currently in use for immersion are expensive and there just are not very good alternatives for expedibles such as cutting or impact tools. This is where the DI water or RO water wash down would come into play. Since they could be washed down and stored in the garage free of oxygen they would last longer.
The ROV and anything venturing out could potentially be made of less costly materials since they wouldn't be coming back to an oxygen environment. You would still need to consider galvanic corrosion.
You could also enclose the BOP or other equipment and place a maintenance robot in the enclosure.
Good Answers: 204
05/13/2010 11:36 AM
a little cross-fertilization... Anything that works on a submarine, at 5000 feet, ought to be applicable, as it has been field tested, and proven successful.
If something is being tried, and hasn't been done before, you have to consider it an experiment.
Great question though, and one that is on every thoughtful person's mind.
Chris
05/13/2010 1:18 PM
Let's stretch the depth and consider the following thought experiment. What would happen to the functionality of the following equipment if exposed to a 2500 up to 40,000 psi nitrogen or helium atmosphere? Consider they would be in their own little environment such as the surface of a gas giant planet. The rate of pressure increase would simulate the rate of descent.
Desktop PC
Pump/motor (Electric or hydraulic)
Industrial robot
Industrial CNC equipment
Batteries
Light sources
Video equipment
Now consider the trip time to and from those equivalant depths and whether you are able to launch at all due to sea state.
Regarding the thruster motors on ROV's. Are the motors fluid immersed or are they using something like a magnetic drive with a sealed motor case?
Good Answers: 150
05/13/2010 3:21 PM
Most electronics cannot handle much in the way of pressure unless they are specifically designed for the environment. batteries, Aluminum electrolytic capacitors, metal can semiconductors and crystals, all would be crushed and unusable. Further hard drives are designed for their heads to fly above the disk surface in the disk surface's "ground effect". if you change the gas that it operates in, you change the fluid dynamics of that airfoil and your hard drive doesn't work.
Who is John Galt?
05/13/2010 3:43 PM
What if you changed to solid state hard drives?
Any way around the crush issue for the batteries, capacitors, metal can semiconductors and crystals? If you left them vented and vacuum impregnated with a compatible material similar to the process of impregnating aluminum die castings would that be a potential solution? If that wouldn't work could you pot everything in a structurally sound potting solution? You would have a great heat sink just outside to cool everything down.
05/14/2010 1:46 AM
unless they are specifically designed for the environment. !
The cost just sky rocketed.
GA Rorschach
Good Answers: 150
05/14/2010 8:05 AM
Yep, that is why electronics for space environments are so expensive, the semiconductor wafers are the same, but they go through special screening and packaging and testing and the cost goes through the roof, same with Mil Spec electronics, again the testing and screening and the packaging is what makes a mil spec 555 timer cost 100 times what a commercial one does. Add in the fact that the lot sizes are relatively small and you throw out any possibility of bringing the prices down through the economies of scale either.
Who is John Galt?
Good Answers: 146
05/14/2010 11:39 AM
".whether you are able to launch at all due to sea state" . I know for a fact this is a genuine issue in the north atlantic - where there are plans for a 2.5 km deep drilling operation.
I believe I heard it on the news after the Sikorsky helicopter crash - rescue crews were unable to use ROV to search for survivors because it was unfit to launch them.
The need for specific conditions to launch the vehicles sort of defeats the purpose of using them in emergencies - most likely to occur in the worst conditions afaict. Severe wind and wave conditions are, after all, a risk factor for accidents and failures.
I have no clue about the subsea garage idea, but a subsea presence of the ROV at all times seems pretty damn necessary to me if it's going to be any use. They can practice their emergency functions down there, come up on a rotation basis for maintenance when necessary and when conditions are good for it.
incus opella
Good Answers: 150
05/14/2010 12:10 PM
most fixed platforms have ROV's launched and operating 24/7. for ships, the problem is that the sea state is constantly tugging on the tethers.
Who is John Galt?
Good Answers: 146
05/14/2010 12:47 PM
I guess the question for fixed platforms would be, if "most" then perhaps it should be a rule to have ROV engaged for all such operations. I'm not sure what regs are followed here - maybe it is a rule already.
incus opella
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
05/14/2010 9:08 AM
The ROV's I've seen into use hydraulic motors, big pump with its own inverter running at about 3000 volts 3 phase, all determined by the cable length and weight of the copper verse the added diameter for insulation. Electronics mostly in armored fluid filled boxes to isolate them from the pressure.
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
05/14/2010 1:31 PM
If the electrical components can't be vented or encapsulated readily in potting compound, how much could be relocated topside since all of the operator interfaces would be there anyway? I assume this same question applies to current ROV's. How much do you really need to enclose in the pressure vessel on the ROV?
Batteries could likely be taken out of the problem category since pressure compensated batteries are already available for ROV's. This would potentially eliminate issues with use of lithium batteries since a substiture would be available.
If vented electronics components were availabe, how would they function immersed in a cooling liquid or gel bath similar to the manner some high end PC's are now available?
05/14/2010 10:47 PM
I found some interesting information on the Siemens Subsea Power Grid. They are claiming large scale subsea processing at 3000 meters depth by late 2012:
http://www.ordons.com/201005044502/siemens-presents-subsea-power-grid.html
Capacitor arranged in a high pressure environment (Sounds expensive)
http://www.wipo.int/pctdb/ja/wo.jsp?WO=2008145639&IA=EP2008056435&DISPLAY=DESC
The effects of space environments on Electronic Components (Nasa):
http://trs-new.jpl.nasa.gov/dspace/bitstream/2014/7193/1/03-0863.pdf
It doesn't appear to say much regarding pressure effects compared to other factors.
Failure Mechanisms in Electronic Products at High Altitudes:
http://www.dfrsolutions.com/uploads/publications/2004_HighAltitude_Hillman-Blattau.pdf
ROV World - Which electronics are pressure sensitive?
http://www.rovworld.com/modules.php?name=Forums&file=viewtopic&p=16431
Containment of downhole electronic systems:
http://www.freepatentsonline.com/5647435.html
Power Electronic Conversion Systems for Deepwater Applications:
http://www.elkraft.ntnu.no/eno/Papers2007/Jacobo-Korea.pdf
Permanent downhole monitoring for extreme temperature and pressure environments:
http://www.onepetro.org/mslib/servlet/onepetropreview?id=00071593&soc=SPE
Magna-Tech Electronics Components Sealing Division:
http://www.magnatechmfg.com/services/electronic.asp
Register to Reply 17 comments
Anonymous Poster (2); artsmith (2); Brave Sir Robin (1); chrisg288 (1); KDS (4); kwcharlie (1); Randall (2); Rorschach (4)
