Another possible means for stopping the oil leak. Would it be possible to stop the leak by lowering a cargo net containing 10,000 pounds or more, of 100 pound standard sandbags, over the leaking pipe? The process could be repeated as required. Sand bags, cargo net, and a boat to lower the cargo net appears to be readily available. If enough sand bags were positioned over the leak the compactness of the bags held in mass by the cargo net, would slow and stop the leak. Other materials could be added to the sand to aid in the sealing, however the additive may not may not be necessary.
