Previous in Forum: Dock Pump to Remove Boat Sewage   Next in Forum: Brakes for Mining Vehicles
Automated Digital Light Timer
02/15/2007 4:53 PM
Hello! I've been looking for someone somewhere to answer a really specific question and I think I might have found the right place!!
For the last 6 months I've been designing a custom light system for my 125 Gallon Piranha Breeding tank to mimic the suns light patterns to initiate breeding behaviour.
Although I've been able to find the perfect bulbs with the correct phosphour coating and Par curve, the automated digital light timer eludes me.
Is there a product in existance that can do or be changed to do the following:
Have 8 seperate timer inputs that can each hold 2 27 watt Light bulbs (2 ground 2 positivive) for a total of 16 27 watt bulbs (Max wattage.., would actually have 12 bulbs and 4 LED moonlights for my tank)
Have a software input so I can set the timers in a schedule like the following:
Timer 1: 7:00am-9:00am - Sunrise
Timer 2: 8:30am-10:30am
Timer 3: 10:00am-12:00pm
Timer 4: 11:30am-1:30pm - Daylight noon
Timer 5: 1:00pm-3:00pm
Timer 6: 2:30pm-5:30pm
Timer 7: 5:00pm-9:00pm - Sunset
Timer 8: 8:00pm-6:00am - Moonlight
I wouldn't want it to stay attached to the computer after I input the software.
And if possible a small CD player like LCD screen would be helpful if there was an option to maybe change timer 1 & 7 so that over the course of the weeks the 7am on 9pm off changes to 8-10 9-11 than back to 7-9
It's pretty basic actually. THe problem is the amount of standard "lamp wire" type inputs required for my task.
If one does not exist but you do have the knowledge and technique to produce a viable product please e-mail me at Ksrhayward@rogers.com as I am willing to work something out for the trouble.
Thank you in advanced! if I posted this in the wrong forumr are please let me know.
- Ottawagoa
Good Answers: 120
Re: Automated Digital Light Timer
02/15/2007 11:24 PM
Keep it simple.
1 Leave the moonlight LEDs on all the time = no timer needed as they are insignificant when the others are on.
2 one timer on from 7 AM to 9 pm 1 level of light
3 one timer on from 8:30 AM to 5:30 PM 1 + 1=2 level of light
4 one timer on from 10 AM to 3 PM 1 +1+1 =3 level of light
5 one timer on from 11:30 AM to 1:30 PM 1+1+1+1=4 level of light
since you have a symmetrical day night pattern, this is all you need.
I might suggest an earlier sunset as equatorial fish are used to 12 hours day and 12 hours of night and your sunrise and sunsets are too long. sun rise and sun set is less than 1 hour in the tropics, often less than 30 minutes
Adjust the bulb wattages to give you the summed daylight pattern.
go to the hardware store and buy 4 of the $10 timers and arrange as I suggest.
If you do not see the concept, I will expand on it
Per Ardua Ad Astra
02/16/2007 12:56 AM
1. LED moonlights are necessary for the cyclical program I have set up. There is a reason I don't want them on in the day as normally the range of light given off by the moon (~475 nm) is blocked out by the typical daylight sun (5500k). In the home aquarium I have, 8 LED blue lights will be a lot more intense than what we currently recieve. 4 would even be too many during the day.
2. Each timer has a different Kelvin Bulb Ratio, to mimic the sun changes from a 2700k - 5500-6500 back to 2700k full day cycle.
Having a 2700kelvin light timer set from 7am-9pm would be an inproper balance of sunlight.
3. The light and timers are not there specifically for intensity. The bulbs I have are rated for the correct lumens per square feet necessary for my tank. Having 12 of these on at one time would burn out my tank, explode in algae and kill off my fish due to oxygen depletion.
The light timer's single function is to produce a sliding kelvin light cycle for my piranhas (east to west) to mimic a full days sun cycle.
I Unfortunately need one that doesn't take one plug input and uses pins to turn on and off, I need one that you connect bare wiring to (+ to -) that just cycles power from one switch to the other.
Here is a picture of how it will be set (It is not 100% perfect and matching to my post but the color coding system will help you understand what i mean)
[IMG]http://img.photobucket.com/albums/v226/Ottawagoa/LightSchedulefor240GallonTank.jpg[/IMG]
- Copy and paste into firefox/IE... i guess html isn't on in these posts
Thanks for the reply though, I appreciate the help.
Any engineers with Digital Timer switch experience please E-mail me ksrhayward@rogers.com I'm willing to purchase working prototypes or one-of-a-kinds if the technology I need isn't in existance but is viable (has to be... not THAT hard heh)
Thanks - Ottawa
Good Answers: 120
02/16/2007 5:44 AM
The use of the leds on all the time is to avoid the cost of the timer for them. Since their intensity will be 1/100,000 of the daylight you can ignore them in your calculations. Besides, in the real world the moon is often in the sky in the daytime.
If you wish a more complex cysle, just set the small manual timers to go on and off as needed. Since this is a niche product with no hope of a volume market it does not make sense using a complex device for a one off system.
If you had the ability to sell 1000 of these a month, then a dedicated computer based controller would work. I find it had to beat these $10 timers, althugh in Canada they may be $15 at radio shack or other place.
Per Ardua Ad Astra
02/16/2007 4:12 AM
A small programmable logic controller with >8 digital outputs will do all that is required, and more.
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?Nr=avl%3auk&N=4294739962&name=SiteStandard&forwardingPage=line&R=4684242&callingPage=/jsp/browse/browse.jsp&BV_SessionID=@@@@1582495764.1171616892@@@@&BV_EngineID=cccladdkediihkecefeceeldgondhgg.0&cacheID=ukie
...is one example of a piece of kit that will do the job (usual disclaimer applies), with a purchase price that isn't too significant a percentage of that of all those exotic lamps and fishes, and won't bite!
Good Answers: 120
02/16/2007 7:42 PM
To protect your personal and contact details your
session has timed out after a period of inactivity
Any items you have on your order form have been saved.
Click here to go back to the RS home page.
Per Ardua Ad Astra
02/16/2007 1:30 PM
If standard timers are not enough, any PLC would do, with just discrete outputs connected to relays or contactors. Using a PLC would give you the ability to cycle during the year the shift in time, and would also have room for expansions and indicators.
You didn't mention where you would like to buy or assemble it. We could help finding a local supplier, if you're not able to do so.
Humm... suspicious you are...
Register to Reply 6 comments
aurizon (3); bhrescobar (1); Ottawagoa (1); PWSlack (1)
