Previous in Forum: Weld Metal Volume Calculator   Next in Forum: Standard Time of Manual Welding
Welding with Smooth Internal Finish
05/17/2010 3:03 AM
For a bottled (mineral) water pipeline how do we weld SS316 so that no bacteria can lodg on internal surface of weld. How to have a smooth internal finish on the welding joint.
Re: Welding with Smooth Internal Finish
05/17/2010 1:00 PM
does the thickness allow for a "backstop"... a small strip of SS316 tacked to the inside of the weld, overlapping the joint would prevent weld splatter.
06/20/2023 9:07 AM
Google "electropolishing".
This forum has no way of assessing the capabilities of the undefined <...we...>.
09/25/2025 9:36 PM
You purge the pipeline with an inert gas like argon or a mix gas like a trimix such as 90% Argon, 7.5% Helium, 2.5% Carbon Dioxide.
now not everyone can weld sanitary piping, you need to get a competent welder to do that.
09/26/2025 4:54 AM
I like to add, if done correctly, the inside finish of the seam will mirror the out side weld bead. if the material wall is thin where a single pass is enough.
Register to Reply 4 comments
Labyguy (1); phoenix911 (2); PWSlack (1)
