Previous in Forum: Application Difference Between SS316 & SS316L   Next in Forum: Thermocouple Testing
Use of 2 SOVs in S/D valves
05/17/2010 3:26 AM
Why 2 SOVs r used in S/D valves?
Pathfinder Tags: 2 SOVs shutdown valves
Re: Use of 2 SOVs in S/D valves
05/17/2010 3:46 AM
It depends on the operating principle of the specific valve. To pick an example, a valve might need to be positively driven open, and also positively driven closed; this could require two solenoid valves as pilots to drive the main valve.
05/17/2010 5:54 AM
Like mentioned in the previous reply it depends much on application
A) If You using Spring Diaphragm It increases Reliability,But rarely used
B) If Your using Double acting Actuator 02 Nos are required Open & Close Commands
Regards
Jose
Register to Reply 2 comments
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
