Previous in Forum: Level differential controller principle?   Next in Forum: VFD Pump Control
Temperature compensation in flow measurement?
05/17/2010 12:57 PM
what is the purpose of using temperature compensation in flow measurement rather than pressure compensation?
Good Answers: 29
Re: Temperature compensation in flow measurement?
05/17/2010 1:25 PM
What kind of flow measurement? For example, both temp and press are integral components of ultrasonic gas flow measurements. We need to know this stuff to help.
05/18/2010 12:56 AM
If you look at Boyles law You will observe Volume is much dependent on Pressure & Temperature .Theoretically if the Pressure and Temperature remain constant, can be neglected but in the nature of gas, Pressure and Temperature will not be constant affected by environment/ process condition,
Regards
Jose
05/23/2010 10:08 PM
Thank you. Now I could understand basic need for compensation in flow measurement. Thank you for your cooperation extend. -chlm.srinivas
05/18/2010 4:51 AM
Please expand the posting. What technique of flow measurement is being used?
Temperature compensation is irrelevant to coriolis mass flowmeters, for example.
Anonymous Poster (1); josej (1); PWSlack (1); RDGRNR (1)
