Previous in Forum: Power Converter   Next in Forum: HOO HA, gettin' married!
Solar Thermal Plant
05/18/2010 10:31 AM
what kind of heat exchanger could I use if I want to preheated compreesed air leaving the compreeser (in gas turbine cycle) by liquid molten salt coming from central reciver solar tower . The molten salt entring the heat exchanger 566C and the air enter with 330C. the air outlet temperature should be as hight as posilbe.
Re: solar thermal plant
05/18/2010 11:24 PM
Sounds to me like a lot of hot air! But then that's the whole idea, after all.... This will entail an extreme-duty HX, on account of both temperature and corrosion possibilities. What sorts of flow rates and air-side pressure are in mind?
05/19/2010 8:41 AM
The air flow rate entering the HX is 104.75 kg/sec . Is shell and tube HX is doing the work with the air in the shell side.
Register to Reply 2 comments
