Previous in Forum: Electrical Engineering Spec Gone Bad.   Next in Forum: Want to Know the Principle of Solenoid Valves
How to Perform a Yacht Electrical Balance
05/19/2010 5:24 AM
Dear sirs
I need information for calculations regarding displacement motor yachts with more then 34 metres.
Can you provide me with ebooks or links to get it? Is there any software available?
Oscar Rodriguez
Portugal
Re: How to Perform a Yacht Electrical Balance
05/19/2010 10:42 AM
Google Archimedes' Principle.
Good Answers: 141
05/19/2010 6:26 PM
If you want to weigh the yacht, lift it out of the water with whatever what can lift it. If you put a weighing cell between each of the lifting points and add the results, that is your weight.
If this is electrical enough, that is one way.
Some devices use hydraulic motors and measure the pressure of the oil, needed to lift- resp. hold, the boat out of the water.
A good manometer, will tell you the weight too.
With pressure - to- voltage or current transducers, in the hydro circuit, you might have a second way of doing it. Most electrical I can think of is measuring the current of your "electric" lifting (winches) motors en make a correlation to the weight. You can use any calculator software that can add.
Plenty of room here
