Previous in Forum: Quick Release Mechanism Must Withstand 50,000 lbs When Fastened   Next in Forum: NDT for SS pipes
ARC Valve
05/19/2010 11:13 PM
is there anyone that can give me a detailed function of an ARC valve on boiler feed water pump and the specific action done....
Re: ARC Valve
05/19/2010 11:42 PM
Good Answers: 137
Re: ARC Valve
05/20/2010 5:12 AM
Hello Lyn
What's the valve doing? Is it for minimum boiler return temperature control? for avoidance of condensation/corrosion in the boiler.
Cheers...........Codey
Re: ARC Valve
05/20/2010 6:33 AM
Pump protection.
From the Tyco website:
Control Valves
7100 ARC Valve for Centrifugal Pump Protection
The 7100 Series ARC provides the most economical and reliable system to protect pumps from the dangers of low and/or reverse flow. It combines the functions of a check valve, flow sensing device, minimum flow control and pressure letdown into a single valve.
Re: ARC Valve
07/18/2010 12:13 PM
L.L. did a good job in showing you the mechanics of the ARC valve.
Are you cognizant of the need to recirculate when pumping hot water with a centrifugal -force type pump?
You can pump a hot liquid with a centrifugal force.... if and when you reach a no flow or low flow condition that will create a vapor pressure situation that can and will cavitate the pump …. you cant pump a vapor with centrifugal force. The ARC valve prevents a no flow condition.
You can still get in trouble if you over temp the feed tank. So daily monitoring is essential.
klearzen
Register to Reply 4 comments
Codemaster (1); klearzen (1); lyn (2)
You might be interested in: Boiler Services, Boiler Controllers, Valve Actuators
