Have a shrink wrapping machine where the vacuum turbines quit suddenly. The fusing is good, the contactor for the turbines (motors?) is good and kicks in at the proper time. However, there is a device called a variable phase angle regulator in one leg of the 2 leg feed to the vacuum turbines. (this is the USA and the voltage is rural 3 phase with 240VAC between phases, but one is a high leg and is 200VAC to ground) This device is made by United Automation of England. Their description says it has a potentiometer for setting the control, fusing and a triac inside it. Basically it is a "black box" with three leads out of a sealed case, as no internal wiring is posted on the manufacturers site. Apparently the fusing is a one and done deal. I suspect this is the culprit. But, what the heck is it?????
