Previous in Forum: rate of CRCA SHEET   Next in Forum: JRDD12
Types of Valves
05/23/2010 3:39 AM
broad classification of valves and how to specify a each valve( technical information for purchasing)?
Re: types of valves
05/23/2010 4:00 AM
Some basic types: gate, globe, ball, butterfly, knife, plug, needle.
Some basic connection types: threaded, socket weld, butt weld, compression, flanged.
Some common materials: brass, bronze, cast iron, ductile iron, steel, many other alloys.
Pressure class; temperature rating.
Handwheel, seal cap, any of several actuators such as manual, solenoid, pneumatic, or hydraulic.
Any of a host of special features.
Fluid to be handled, which will dictate some of the foregoing.
It's easy; the world is your oyster. Sally forth!
Re: types of valves
05/23/2010 4:06 AM
I think the right size (bore) might help too.
Re: types of valves
05/25/2010 6:35 AM
thank you sir for your kind inforation.
but want futher in depth. information details
1. anti siphon valve
2. ball valve cromium plated
3.ball valve compression type.
4. ball vale flanged type
5. ball valve reflex type
6.ball valve screwed type
7.ball valve threaded type
8.butterfly valve flanged
9.block and bleed valve
10. check valve dual
11. check valve dual plate
12. choke vale
13.control valve comination
14. discharge bye pass valve
15. double block and bleed valve
16 double regulator valve
17.dynamic valve
thanks,
regards
moahansundaram
email id: rmohan19802010@gmail.com
Re: types of valves
05/23/2010 9:42 AM
This type of question is just like homework, except this guy is being paid to perform a function about which he knows nothing.
Oh well. Maybe they are a quick study.
lyn (1); mohanasundaram (1); Tornado (1); user-deleted-1105 (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
