Previous in Forum: Looking for a Welding Electrode Selection Book   Next in Forum: Power output down
Engineering Fields - Piping Design Engineering - New Member
Pressure Vessel - ASME Section VIII
05/24/2010 2:56 AM
Hi All,
What is Class 1 Pressure Vessel and Class 2 Pressure Vessel? Is there any difference between these two?
I am new to pressure vessel design area. I found the term like "Class 1 PV" and "Class 2 PV" while I was reading a report on pressure vessel design of Air Receiver Tank.
I tried to get it in ASME Section VIII, but I could not get clear picture how it is different.
Thanks,
Nayek
Re: Pressure Vessel - ASME Section VIII
05/24/2010 9:05 AM
Assuming you are referring to Division I & Division II... I offer the following: (Source ASME)
Also listed is the Reference material for each division. Costs about $US600.00 ea. New. But I am sure you can pick up some used publications along the way.
DIV I
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig.
Such pressure vessels may be fired or unfired. Specific requirements apply to several classes of material used in pressure vessel construction, and also to fabrication methods such as welding, forging and brazing.
It contains mandatory and non mandatory appendices detailing supplementary design criteria, nondestructive examination and inspection acceptance standards. Rules pertaining to the use of the U, UM and UV Code symbol stamps are also included.
BPVC-VIII - 2007 BPVC Section VIII-Rules for Construction of Pressure Vessels Division 1
DIV II
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig. Such vessels may be fired or unfired.
This pressure may be obtained from an external source or by the application of heat from a direct or indirect source, or any combination thereof.
These rules provide an alternative to the minimum requirements for pressure vessels under Division 1 rules. In comparison to Division 1, Division 2 requirements on materials, design, and nondestructive examination are more rigorous; however, higher design stress intensity values are permitted.
Division 2 rules cover only vessels to be installed in a fixed location for a specific service where operation and maintenance control is retained during the useful life of the vessel by the user who prepares or causes to be prepared the design specifications.
These rules may also apply to human occupancy pressure vessels typically in the diving industry. Rules pertaining to the use of the U2 and UV Code symbol stamps are also included.
BPVC-VIII-2 - 2007 BPVC Section VIII-Rules for Construction of Pressure Vessels Division 2-Alternative Rules
Div III
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures generally above 10,000 psi.
Such vessels may be fired or unfired. This pressure may be obtained from an external source, a process reaction, by the application of heat from a direct or indirect source, or any combination thereof.
Division 3 rules cover vessels intended for a specific service and installed in a fixed location or relocated from work site to work site between pressurizations.
The operation and maintenance control is retained during the useful life of the vessel by the user who prepares or causes to be prepared the design specifications.
Division 3 does not establish maximum pressure limits for either Section VIII, Divisions 1 or 2, nor minimum pressure limits for this Division. Rules pertaining to the use of the UV3 Code symbol stamps are also included.
BPVC-VIII-3 - 2007 BPVC Section VIII-Rules for Construction of Pressure Vessels Division 3-Alternative Rules High Pressure Vessels
"Source: ASME"
05/27/2010 11:39 AM
Thanks for your reply.
some more points have been noted in that design report, saying that
if the capacity of pressure vessel (in terms of bar.litres) exceeds 40000 bar.litres then pressure vessel come into class 2 category. If the capacity is within 40000 bar.litres then it is in class 1 category.
I dont see any such kind of notation in ASME Section VIII Code. Is there any other code which refer this kind of rules?
03/14/2011 10:36 AM
HI,
can anyone let me know where can i find the thickness of outershell of a vacuum brazing furnace, details of thermocouples to be used, dimensions for flanges , vacuum port, water port, water jacket, front door mechanism, rear door mechanism and mounting legs all as per the Asme pressure vessel code section VIII, Div.1.
Its really very urgent, plz help me out.
Thank you
Rahul singh
07/15/2026 6:41 AM
A very informative discussion on ASME Section VIII classifications and pressure vessel design requirements. Understanding the differences between Division 1, Division 2, and high-pressure applications is essential for ensuring safety, compliance, and cost-effective vessel design in industrial projects.
In practical applications, proper material selection, fabrication quality, inspection procedures, and code compliance are just as important as the design calculations themselves.
For organizations looking for engineered pressure vessel solutions, Nord Stone manufactures custom pressure vessels, heat transfer equipment, distillation columns, storage vessels, and process equipment in accordance with international standards for oil & gas, chemical, power, and industrial sectors.
05/09/2012 6:38 AM
"Unfired" Pressure Vessel Rules Alternative Rules Alternative Rules for High Pressure
Published
< 1940 1968 1997
Pressure Limits
Normally up to 3000 psig No limits either way, usually 600+ psig No limit; Normally from 10,000 psig
Organization
General, Construction Type & Material
U, UG, UW, UF, UB, UCS, UNF, UCI,
UCL, UCD, UHT, ULT
General, Material, Design, Fabrication
and others
AG, AM, AD, AF, AR, AI, AT, AS
Similar to Division 2
KG, KM, KD, KF, KR, KE, KT, KS
Design Factor
Design Factor 3.5 on tensile (4* used
previously) and other yield and
temperature considerations
Design Factor of 3 on tensile
(lower factor under reviewed) and other
yield and temperature considerations
Yield based with reduction factor for
yield to tensile ratio less than 0.7
Design Rules
Membrane - Maximum stress
Generally Elastic analysis
Very detailed design rules with Quality
(joint efficiency) Factors. Little stress
alaysis required; pure membrane
without consideration of discontinuities
controlling stress concentration to a
safety factor of 3.5 or higher
Shell of Revolution - Max. shear stress
Membrane + Bending. Fairly detailed
design rules. In addition to the design
rules, discontinuities, fatigue and other
stress analysis considerations may be
required unless exempted and guidance
provided for in Appendix 4, 5 and 6
Maximum shear stress
Elastic/Plastic Analyses and more.
Some design rules provided; Fatigue
analysis required; Fracture mechanics
evaluation required unless proven leakbefore-
burst, Residual stresses become
significant and maybe positive factors
(e.g. autofrettage)
Experimental Stress
Analysis
Normally not required Introduced and may be required
Experimental design verification but may
be exempted
Material and Impact
Testing
Few restrictions on materials; Impact
required unless exempted; extensive
exemptions under UG-20, UCS 66/67
More restrictions on materials; impact
required in general with similar rules as
Division 1
Even more restrictive than Division 2
with different requirements.Fracture
toughness testing requirement for
fracture mechanics evaluation
Crack tip opening displacement (CTOD)
testing and establishment of KIc and/or
JIc values
NDE Requirements
NDE requirements may be exempted
through increased design factor
More stringent NDE requirements;
extensive use of RT as well as UT, MT and
PT.
Even more restrictive than Division 2;
UT used for all butt welds, RT otherwise,
extensive use of PT and MT
Welding and
fabrication
Different types with butt welds and
others
Extensive use/requirement of butt welds
and full penetration welds including nonpressure
attachment welds
Butt Welds and extensive use of other
construction methods such as threaded,
layered, wire-wound, interlocking stripwound
and others
User
User or designated agent to provide
specifications (see U-2(a))
User's Design Specification with detailed
design requirements (see AG-301.1)
include AD 160 for fatigue evaluation
User's Design Specification with more
specific details (see KG-310) including
contained fluid data, etc with useful
operation life expected and others.
Designer defined
Manufacturer
Manufacturer to declare compliance in
data report
Manufacturer's Design Report certifying
design specification and code compliance
in addition to data report
Same as Division 2
Professional
Engineer
Certification
Professional Engineers' Certification of
User's Design Specification as well as
Professional Engineer shall be experienced
in pressure vessel design
Same as Division 2 but the Professional
Engineer shall be experienced in high
pressure vessel design and shall not sign
for both User and Manufacturer
Safety Relief Valve
UV Stamp UV Stamp UV3 Stamp
Code Stamp and
Marking
U Stamp with Addition markings
including W, P, B, RES; L, UB, DF; RT,
HT
U2 Stamp with Additional marking
including HT
U3 Stamp with additional marking
denoting construction type; HT, PS, WL,
M, F, W, UQT, WW, SW
Hydrostatic Test
1.3 (Was 1.5 before the use of the 3.5
Design Factor in the 1999 Addenda)
1.25
1.25 (may be exempted for
autofrettaged vessels)
* In 1998, Code Cases 2278 and 2290 for ASME Section VIII Division 1 allowed for alternative maximum allowable design stresses based on a
a factor of 3.5 under certain provisions instead of a factor of 4 used by the Code. These code cases were incorporated into the Code in 1999.
Anonymous Poster (2); Aruna Weblogicks (1); mechforge (1); rurudr (1)
