Previous in Forum: Pipe Reducer From M S Pipe   Next in Forum: Welding of Thin Stainless Steel
Valve Detail Request
05/25/2010 4:37 AM
i want to know how to oder the following types of valves . and i want the catlouge which clearly spefiy the following detail.
1. anti siphon valve
2. ball valve cromium plated
3.ball valve compression type.
4. ball vale flanged type
5. ball valve reflex type
6.ball valve screwed type
7.ball valve threaded type
8.butterfly valve flanged
9.block and bleed valve
10. check valve dual
11. check valve dual plate
12 choke valve
13.control valve comination
14. discharge bye pass valve
15. double block and bleed valve
16 double regulator valve
17.dynamic valve
- valve types, end connection types,body types,sealing stucture types, driving type
with regards
mohan
Good Answers: 29
Re: i want a detail about valves can any suppier or manufacturer can clarify?
05/25/2010 8:47 AM
Start here.
05/25/2010 9:02 AM
I give you a pat on the head for patience.
05/25/2010 9:05 AM
sir,
i want the classification of valves example. ball valve globe valve,dynamic valve ... etc.. and technical information about it . for example size, type,connection type... etc. i want full details
with regards
mohan
05/25/2010 9:17 AM
RDGRNR has given you an excellent start in gathering the information you demanded in your first overbearing post.
What an insult it is for you to come back and demand that he do the rest your job for you. What do they pay you for? Intimidating other people into doing your work for you?
Grow up, or get your mother to do your work for you!
Re: Valve Detail Request
07/31/2010 11:49 AM
If you need Abrasion-resistant valve,Corrosion resistant valve or hight-temperature valve...Our ceramic-lined ball valve will be the best choice.Long service life in high-abrasive application.1 year warranty usually.
arthurzhuo (1); lyn (2); mohanasundaram (1); RDGRNR (1)
