I have replaced fuel pump, fuel filter, pressure regulator, spider injector set up, Distributor module, and computer. The engine turns over and fires on starting fluid. Fuel pumps up while turning over, the injector triggers are not firing. Power going into the injector pump and out of the injector pump. If you ground the wire coming out of the injector pump you can hear the trigger otherwise no luck. Thought about driving the safari on starting fluid but too costly.
Any suggestions?
Thank you in advance
