I purchased this car about 2 1/2 years ago from my mother-in-law who doesn't drive. The car sat in the garage for 6 years since my father-in-law passed away. When I bought it, the car had only 20,000 miles (not a typo). I replaced all of the tires, new car battery, and changed all of the fluids (radiator, brake, oil, and transmission).
About a week ago, I drove about 10 miles and at the stop light, the transmission slipped. The car wouldn't move while it was on Drive. I changed the gears and nothing happened. I turned off the engine and restarted the car and was able to drive about a mile and it happened again. It happened several times.
Someone told me to check the transmission fluid and it was low and I've added about a quart and a half. Before I added the transmission fluid, I started the car and while in park, I noticed that the "Reverse" gear is noisy (clicking and clacking noises) and the car would not go in reverse. After putting in the transmission fluid, the noise stopped and the reverse gear worked fine. I thought the problem was fixed. Then, yesterday, I drove only 5 miles and the transmission slipped again.
Any thoughts on what the problem is? Do I really need to replace the transmission with only 35,000 miles on it or change the transmission fluid "and" replace the pan gasket and filter? Thanks for your suggestions
