Previous in Forum: ASME Welding Rod A Number?   Next in Forum: Inspector-Welder Ratio
Percent Yield in Manufacturing Plant
05/27/2010 5:22 AM
what would be the acceptable % yield in the manufacture and filling in 1 gallon bottles of a watery consumer product? thanks
Re: % yield in manufacturing plant
05/27/2010 6:03 AM
I'd say it depends on the value of the product, but I'd guess 0.1% tops. I have no experience in this field, 'cos I'm a cat.
Re: Percent Yield in Manufacturing Plant
05/29/2010 6:11 PM
Irrespective of the product, % yield for bottled foods, drinks,beverages and other related foods should range between 98-100%. Anything below this is not okay.In some cases(beverages) you can have yield above 100% depending on the efficiency of the equipment and operation process.
Your yield% is calculated from the following formula
Yield%=(Actual quantity of goods produced/Theoretical quantity of goods expected)%
When you can express what you are speaking about mathematically, then you really know something about it.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
06/01/2010 5:32 PM
As a foreman of a seed packaging plant, we expect nothing less than 98%. I would expect a liquid process to be no less than 99%
Give me enough duct tape and I can fix anything!
06/02/2010 12:31 AM
Thank you for all the reply.
For a liquid batch would it be acceptable to have a certain overyield? If there is, what %would that be?
06/14/2010 10:46 PM
Yes, it's possible to have over yield in liquid batches. The base ingredients usually comes with a certain percentages factored in to cover for wastages, spilling, sampling, flushing etc. If the wastage is minimized and controlled as much as possible, you will come up with yield ranging from 101-107%.
In bottling industry where I work, if you control underfilling, crown and caps misapplication,breakages, overfilling, carbonation etc, you will have yields higher than expected.
Curiousinthephilippines (1); farmatt (1); TOPE (2); user-deleted-1105 (1)
