Previous in Forum: Relay and Electrical junction box supplier in Vadodara   Next in Forum: Voltage drop
Regulators or VFDs
05/28/2010 12:07 AM
Hello everyone,
I was wondering, if we could reuduce the speed of Fan using regulator (i.e. we can control the spped of ac motor with the potentiometer), why do we use VFD (Variable Frequency Drives) to control the speed of Three phase motors in any industry ?
Is it because of single and three phsaes..
kindly help me understand this basic guys..
Pathfinder Tags: Regualtor Vs VFD
Re: Regulators or VFDs
05/28/2010 12:24 AM
This is not the place for basic...(or basic guys as you wrote)..... Please everybody, do not entertain this type of booze support questions.
05/28/2010 12:52 AM
Dear Sir,
Using a regulator ( stepped or stepless) to control fan is good idea where
you need a blind control. You use a VFD where you need precise control of the
system with a feed-back loop ( like precise positioning of lift landing).
Do not be spoon fed if you want to grow in your carrier.
S.Poornam.
05/28/2010 1:26 AM
To the Guest:
I belive Your are not the organiser or provider of this forum, so kindly restict urself from declaring those statements,
Dear thanks for your reply. If u think iam spoon fed. then dont spoil me. I know my way to knowledge
05/28/2010 1:46 AM
The speed of DC and certain types of (usually small single-phase) AC motors can be controlled by voltage (potentiometer). The speed of most industrial motors can be controlled by frequency (VFD). It has to do with the design characteristics of the motor.
Good Answers: 244
05/28/2010 9:52 AM
First of all, it seems to me a valid question and the question has also been indirectly answered in the recent thread http://cr4.globalspec.com/thread/55009.
It is correct that the speed of the induction motor can be controlled by controlling the motor supply voltage but the concern is the torque developed by the motor with reduced voltage. The torque developed by the induction motor is directly proportional to the square of the motor terminal voltage. So, with reduced voltage, the torque developed by the motor is drastically decreased and the motor is not able to drive the load that requires constant torque (which is the case for most of the motor loads). However for certain loads, which are not constant torque load (such as fan and blower), voltage control method can be used to control the speed.
In addition, the motor draws more than the rated current to keep the load running up to its breakdown torque with reduced voltage with the possibility of motor burn or overload trip.
Also see:
http://cr4.globalspec.com/thread/54011/Torque-Squirrel-Cage-Induction-Motor
http://sureshks.netfirms.com/article/stator/stator.htm (read "2. Stator Voltage Control for Speed Control of Induction Motor")
Hope it is clear now.
- MS
Anonymous Poster (1); manroop (1); msamad (1); seeker123 (1); Tornado (1)
