Previous in Forum: Walk Behind Forklift Stuck on Forward (Crown 30WT)   Next in Forum: Chainsaw Boiling Oil
diesel engine
05/29/2010 7:58 AM
The ONE MVA generator consuming fifteen litres lube oil for one hour at 600 KW LOAD WHAT MAYBE THE REASONs
Re: diesel engine
05/29/2010 10:38 AM
What is the make and model of the engine? How often is it run? Did this problem just start now or has it been getting worse over time? You are referring to engine oil and not fuel, correct? Where is the gen set located-- closed building , outside, Need to know more info. Thanks
Good Answers: 60
Re: diesel engine
05/29/2010 11:23 AM
where is the oil going ?
is it leaking.
if the rings have worn or broken its possible for a diesel engine to burn the oil as fuel.
you would notice more smoke than normal, also it would smell more.
try giving us more information.
Re: diesel engine
05/29/2010 8:25 PM
Peter I like your closing expression. It reminds me of another one, "When I'm right nobody remembers, and when I'm wrong nobody forgets". I hope these disclaimers don't discourage the gentleman we're trying to assist.
h
Register to Reply 3 comments
