Previous in Forum: Gas turbines   Next in Forum: Refrigeration Unit Evaporator Choking Problem
compressors
05/29/2010 8:47 AM
Hi
Advantages of a two stage reciprocating compressor with inter-cooling over a single stage compressor and p-V diagram
deepcut1
Re: compressors
05/29/2010 9:37 AM
Another homework?
Good Answers: 101
Re: compressors
05/29/2010 8:17 PM
Hi
What happens when you compress air
Re: compressors
05/30/2010 7:43 AM
What do you mean, i need help
deepcut1
Good Answers: 101
Re: compressors
05/30/2010 10:32 AM
When you compress air it heats up and requires increasing amounts of energy to continue compressing it. A two-stage compressor with intercooler will cool down the heated air, thus requiring less energy to compress it to higher pressures.
Really, you should refer to your physics textbook instead of simply posting questions here. Turn to the section on gas laws. For one thing, doing your own research will turn up lots of valuable information that would help you in your studies and future career. For another, I've been known to sometimes deliberately post wrong answers here to teach wannabe homework cheats valuable lessons in honesty. There, now you're likely to have doubts about the reliability of my clarification.
Oh, and I doubt it would kill you to use proper grammar and punctuation to make yourself more readily understood.
Re: compressors
05/30/2010 6:20 PM
Hi
This is not being a home work cheat as you expressed it, I did some research but I could not find satisfactory answers so I want you to reinforce my research not calling me a cheat.
Most of the explanations are not exact, hope this will clarify my position to you.
Thanks
deepcut1
Good Answers: 101
Re: compressors
05/30/2010 8:18 PM
My apologies. You should have made it clear because we get a lot of homework cheats asking such similar questions here. And for the record, the information I gave you is correct.
Good Answers: 19
Re: compressors
05/30/2010 12:57 AM
Economy
Register to Reply 7 comments
Anonymous Poster (1); deepcut1 (2); ducon (1); DVader1000 (3)
