Previous in Forum: Increase in Axial Shift and Thrust Bearing Temperature   Next in Forum: Photovoltaic Power Unit
14 comments
Fresnel Lense
05/29/2010 11:18 PM
Would like to have information on how to produce fresnel lense and the machines which are used to produce fresnel lenses.
Re: fresnel lense
05/29/2010 11:39 PM
These are normally produced by injection molding.
Unless they are glass, of course.
Have you done any research, other than coming here?
Like maybe Googling fresnel lense?
Fresnel lens - Wikipedia, the free encyclopedia
My God! Are you all totally helpless??????????????????
Re: fresnel lense
05/30/2010 12:04 AM
Thanks for your reply.Can the die cavity of mold fill with hot runner system giving all the details?The material used is PMMA.I read that compression molding can also be used for this.Also tooling is very critical.
regards
ashok
Re: fresnel lense
05/30/2010 9:29 AM
"Can the die cavity of mold fill with hot runner system giving all the details?" Yes, if the proper grade of acrylic is used. "I read that compression molding can also be used for this." It can be. Cycle times will be much longer.
You could also mix your own liquid PMMA and pour it into an open top mold and cure it. This would be the slowest process.
Good Answers: 101
Re: fresnel lense
05/30/2010 10:03 AM
Scary thought. It sounds like he wants to set up a plant to produce Fresnel lenses without knowing how it's actually done.
Re: fresnel lense
05/30/2010 10:08 AM
For people such as this, ignorance of the facts is rarely a deterrent.
At least he hasn't asked how to hook up the 440V service, yet.
Good Answers: 101
Re: fresnel lense
05/30/2010 8:15 PM
Now that would be really bad.
Re: fresnel lense
05/31/2010 12:47 AM
That reminds of the story about an electrical maintenance chap called in to set right a HT line blown down in high wind. He asks his helper to move aside one of the bare cables lying on the ground. The helper pushes it aside and asks what next. The electrician says,' Then the other one must be the HT cable'. Bioramani
bioramani
Good Answers: 101
Re: fresnel lense
05/31/2010 8:45 AM
Good one.
Re: fresnel lense
05/31/2010 1:33 AM
Mark Twain has said "To be successful, you should be ignorant and confident". OP has bot these, he will be successful.
Re: fresnel lense
05/31/2010 6:54 PM
you wrote...
No, just lazy. Will not even go to the spell checker.
Wangito.
Never trade luck for skill.
Re: Fresnel Lense
05/31/2010 1:00 AM
http://www.fresneltech.com/pdf/FresnelLenses.pdf http://www.fresneltech.com/tooling.html bioramani
bioramani
Re: Fresnel Lense
05/31/2010 3:07 AM
For that matter, the spelling "lense" was a likely tipoff of naiveté.
Re: Fresnel Lense
06/14/2010 9:23 AM
En Espanol:
Spoken: Lense
Written: Len se
Translation: Len itself
Len: Applied to soft, untwisted silk.
Translation: Applied to soft, untwisted silk itself.
Comprende?
Re: Fresnel Lense
06/14/2010 10:39 AM
¡Muchas gracias!
Register to Reply 14 comments
Anonymous Poster (1); bioramani (2); DVader1000 (3); gsuhas (1); lyn (3); pashok (1); Tornado (2); wangito (1)
